Old 09-22-2011, 06:29 PM   #1
buda's Avatar
Question Removing front window frame- '62
Hello; how do I remove the frame on the front window of my 62 24 tradewind.
I removed the small screw in the middle of the frame, and I raised the frame up to try and unhook it but it won't release.
Bud 62/24/ tradwind
buda is offline   Reply With Quote
Old 09-24-2011, 11:55 AM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Bud 62/24/ tradwind
You will need to raise the window to horizontal and the window should slide out. The "eye brow" corner will probably need to be gently bent up to allow the window to slide out. There should be a screw in corner "eye brow" to allow the bending. This might help too.Restoration Topics - Window Repairs
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 13 01-05-2012 06:41 PM
Removing window frames '61 GT streamahead Windows, Doors, Locks & Vents 3 07-30-2011 09:47 AM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
2007 Classic front center window glass/frame interference dznf0g 2006 - 2010 Classic (all lengths) 0 03-23-2011 09:44 AM
Front window leak fix? BarnacleBill Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 7 01-18-2011 05:04 PM
