Hello!
We're having some significant trouble removing the corrosion that has built up over the years on our aluminum window frames (pictures below).
Here's what we've tried so far:
- Maroon scotch brite pads with WD-40
- Wet sandpaper (various grits)
- Roloc polishing discs, 80 and 120 grit (photo below)
We've actually made some pretty great progress, BUT there's still a small, very annoying amount of corrosion visible on the window frame.
Our question is:
Is there any way to remove the remainder of the corrosion and end up with a nice, smooth, solid looking surface? Are we fighting an uphill battle here and it's not going to get much better?
Any help or suggestions would be much appreciated!
