Old 01-18-2010, 08:20 PM   #1
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Removed window - can't reinstall
I've been removing windows to replace gaskets/seals. I got to one that seems to have a slight kink in the track that the window clips into at the top. I can't seem to get the hinge to fit back in because of this. Any suggestions? I spent 45 min. trying to force it in but I don't want to bend the hinge.
adwriter73 is offline   Reply With Quote
Old 01-18-2010, 09:01 PM   #2
For the front and rear window, it takes 2 people to reinstall it.
Raise the window high. Each person engages each end. Then the taller or person with the longer arms, hits the center of the hinge on the window with their fist, to pop it in place.
When the window is positioned just right, the center part of that hinge will then engage.
SLOWLY lower the window and watch the hinge like a super hawk. If the hinge is binding, start over, by going up a little higher.
Again, slowly lower the window, and observe what the hinge is doing in the middle. If the hinge has engaged ok, then the window will lower without any resistance.
CAUTION If you bend either half of the hinge, you have a problem. Typically the window hinge may bend. If so, get the window on a bench and straighten the hinge, and start over.
One person cannot, without a huge risk, install the front or rear window, and sometimes not even a large curved window.
Good luck, take your time, AND be patient.
Old 01-19-2010, 04:29 PM   #3
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
I actually did the rear window by myself! : ) One side does look it bent slightly. I will water-test it for leaks to be sure. The window I am having trouble with is a side window. I will get some help putting it in. Maybe the two of us carefully working it will get it in...Question about hinges. One of the hinges on another window has separated slightly from the window frame on one side. Are those rivets holding them on? One is loose. I can wiggle it freely. What should I do?
Old 01-19-2010, 04:35 PM   #4
Tighten every rivet that's loose.
You may have to remove the gasket in order to do that properly. If so, do it.
If the gasket has aged out, then replace it.
You can only use small buck rivets for the hinge. Pop rivets and Olympic rivets would cause more damage.
Old 01-19-2010, 06:40 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I am assuming you don't have ready access to buck rivets, if any of the rivets break when you take the window out, you can use pop rivets to replace them. However, when you install the pop rivets, make sure you put them through from the back side of the window/hinge so the head faces in. If not, the expanding part of the rivet will crush against the window frame.
Old 07-08-2010, 12:36 AM   #6
Cottonwood , Idaho
Wait, so can pop rivets be used to reattach the hinge to the window frame? Or will the pop rivets really do more damage, as Andy said? I know this is kind of an old thread, but I am in the process of replacing all the weatherstripping on our 71 Tradewind. In the process of taking out the rear window, 4 or 5 of the rivets broke in half on the J hinge. I have been wondering how to reattach the hinge back onto the window frame. Still have 4 of 7 windows to go, so still a little time left to "wonder."
I am a new AS owner (1 yr), and to forums. Already have learned so much from the conversations and wealth of info here.
Magic Bean is offline   Reply With Quote
Old 07-08-2010, 07:12 AM   #7
You can use pop rivets,but they must be installed backwards so that the head of the rivet will be covered by the gasket.
Small buck rivets of course are the best for the looks.
Old 07-08-2010, 09:45 AM   #8
Maniacal Engineer
barts's Avatar
Menlo Park , California
Before attempting to fit the window, clean the lip on the window of any and all corrosion; I used a small stainless brush and Scotch-Brite pad. Then lubricate the lip with silicone spray front and back, applied w/ a rag.
Installation should be done slowly and carefully. The material that forms the window frame may not be perfectly straight in the plane of the window, and the window may need to move slightly in the gasket. Three people can be very useful in this case; one at either end (probably on ladders) supporting the window and one in the center, pressing on a wood block against whatever part of the hinge is not slipping into position as observed by the folks at the ends.
This can be somewhat tension producing, so relax and take your time.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 07-08-2010, 04:12 PM   #9
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
This is an old thread, but I STILL have not gotten the window in place. Oddly enough, I picked up a tool today that will hopefully help straighten out the kink in the track that the window clips into. If that doesn't work, then I am just going to have to remove the track, repair and then reinstall -- could be a big project.
Old 07-08-2010, 05:48 PM   #10
1960 24' Tradewind
Riverside , California
You'll need a 20" 2 x 4 for a medium window and a 30" 2 x 4 for a large window, 2 people and a 3# sledge hammer, tap the hinge into the mating hinge while someone holds the window at a little above 90 degrees.
Greg
1960 Tradewind
2007 Denali 6.2
2005 ST 1300 ABS
2005 Chevrolet SSR 6.0 LS2
airstreamlosangeles.com
ZoomZoom is offline   Reply With Quote
Old 03-26-2012, 05:31 PM   #11
1970 31' Sovereign
Burnsville , North Carolina
This may be an old thread but it sure is useful. The Forum continues to amaze me with the breadth of its shared knowledge. Thanks!
Bill
CeloNC is offline   Reply With Quote
Old 03-27-2012, 10:41 AM   #12
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Forgot to follow-up on this. I ended up replacing the "eyebrow" frame on mine with one off a salvaged '70s Airstream. It seems mine was kinked in a way that I couldn't get the window back in.
Old 12-31-2012, 01:15 PM   #13
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
I know that this is on old post...
Are these installed backward so the gasket seals the pop rivets, or would the pop rivets keep the widow from closing? Thanks !
Silverflames is offline   Reply With Quote
Old 12-31-2012, 06:12 PM   #14
The pop rivets would keep the window from closing, as well as damaging the hinge.
'97 Safari 25' - reinstall of couch & jacks mkrushr 1997 Safari 2 07-21-2017 07:04 AM
What to use to reinstall black trim? whitelight Clearcoat, Exterior Paint & Trim 4 03-02-2010 08:28 AM
Removed awning... WILDRTEXAS Awnings 10 12-03-2009 06:47 PM
New vinyl walls before reinstall? Minno Upholstery, Blinds, Walls & Interior Finishes 10 08-07-2009 04:19 PM
Has any one just removed.... tyndalelady Upholstery, Blinds, Walls & Interior Finishes 4 01-26-2006 11:12 AM
