Old 02-24-2016, 12:50 PM   #1
1970 23' Safari
Elkhart , Indiana
Remove original exterior rivets?
Ok so I finally found my stack window. Now I have to remove the broken one and install the new one. I'll be installing the new one with Olympic rivets. But how do I remove the window without damaging the exterior skin and holes? I don't want to buy any special tools. Thanks in advance
Thill_1985 is offline   Reply With Quote
Old 02-24-2016, 02:53 PM   #2
JimGolden's Avatar
1977 31' Excella 500
Rivets are typically drilled out. You start with a good sharp punch and make a mark dead center in the head. Then use a small bit on a high speed drill to run a pilot hole through it. Then follow it with a second bit that is the same diameter as the rivet shank. Then the head just falls off. You'll most likely need to replace it with the next size larger.
You might be able to drill it in one step, but I've had better luck doing it in two steps.
Best of luck,
- Jim
JimGolden is offline   Reply With Quote
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 12:53 PM
Will this part help remove exterior rivets? bennyg Ribs, Skins & Rivets 6 11-17-2011 09:01 AM
Buck rivets or Olympic rivets? Sparkygus Ribs, Skins & Rivets 20 02-28-2009 08:33 AM
Lousy Rivets!/Weak rivets sunk the Titantic? 1956Safari Off Topic Forum 14 04-18-2008 01:35 PM
Olympic Shaved Rivets vs. Buck Rivets with Dimple msjaarda Ribs, Skins & Rivets 8 03-16-2007 10:00 PM
