Old 10-06-2008, 04:22 PM   #1
1972 29' Ambassador
Saint Petersburg , Florida
Removal of Curved Window
I have a 72 Ambassador that has water stains between the glass on the front curved window. This window was repaired by a prior owner and is covered in caulking. I looked at the other one and cannot see how it comes apart. I cannot find an existing thread on this. Does anyone know of a picture step by step or has an exploded parts view of this window. Any help would be appreciated.
gbroughman is offline   Reply With Quote
Old 10-06-2008, 04:36 PM   #2
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Sounds like a hack job; those are the hardest to fix since the window sizes changed from
coach to coach. I'll bet the previous owner got one too small & tried to caulk it shut.
This is something for the pros; they'll add a little piece of metal to make up the
difference. Been there.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 10-06-2008, 08:00 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The wing window is usually a dual pane assembly, and is not very easy to disassemble and put back together without breaking one of the panes. If is doesn't leak now, Try removing the mounds of caulking, and resealing it with vulkem. Our trailer has high water marks between the panes, even after I drained the water out of it.
Curved window Canstreamer Windows & Screens 0 10-30-2006 03:47 PM
Curved side window replacement michel88 Windows & Screens 7 09-29-2006 09:20 AM
curved window for 79 MH piratesrus Airstream Motorhome Forums 1 07-16-2003 09:21 AM
Broken front right curved window RREGESTER Windows & Screens 1 02-09-2003 09:05 PM
