Old 11-21-2015, 05:49 PM   #1
Rebuilding Windows
I have taken my windows completely apart. I have purchased both the u gasket and the gasket that has the ribbed things on it. I cannot get either to fit back in the aluminum frame. I have trimmed them, lubed them, and hammered and cannot get to fit. 1970 sovereign with the thicker glass. What am I doing wrong considering buying all new Windows since I cannot fix these but that will be pricey.
paulmichie is offline   Reply With Quote
Old 11-23-2015, 10:52 AM   #2
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
Hey Paul those windows are still giving you grief huh? Where did you buy your gasket from? I have a small scrap leftover from doing mine that I can mail you to try if you would like. I bought it from Vintage trailer supply and they call it for the 1970's window glazing strip.
I have a small piece of broken glass in my car cupholder that came from my '69's rear window and it is only 1/8 thick but I know that window was replaced in the past so it may be not the factory original thickness, so when I redid my back window I used 1/8th tempered and the Vintage trailer supply glazing worked great. If it is just your front and rear window you are replacing at this point it may be worth ordering new thinner tempered flat panels. The side and wing windows on the other hand are curved and you will want to keep looking for the appropriate sized glazing strip as getting replacement glass for those is impossible and swapping out good glass for thin lexan would be blasphemy (not that you mentioned doing that)
1970 Airstream Window Glazing Strip
thesignlady is offline   Reply With Quote
Rebuilding '70s vintage wing windows, need some examples aquinob General Repair Forum 9 01-03-2015 09:29 AM
Rebuilding Wet Oval Stack Windows dbj216 Windows, Doors, Locks & Vents 0 06-18-2012 04:34 AM
Windows, windows, windows... Balquin Windows & Screens 4 07-04-2006 06:35 PM
Top ten things about rebuilding a new trailer campcollector 1997 - 2004 Bambi 2 02-27-2004 04:56 AM
Front floor area and rebuilding dresser jeanarlene 1969 - 1973 Safari 10 09-05-2002 11:11 AM
