Old 05-27-2013, 11:27 AM   #1
1962 19' Globetrotter
McGraw , New York
rear window replacement
hello all,
the previous owner put a house window ac in our 62 globetrotter, does anyone have a window or know the best way to go about having one made?
thanks,
Steve
John316 is offline   Reply With Quote
Old 05-27-2013, 02:07 PM   #2
1962 22' Flying Cloud
1964 24' Tradewind
Murray , Utah
Steve,
We really need a little more info here.. Like does the original frame exist? And has it or the opening been modified? If the frame is present, then you have an easier fix, so long as the frame welds are still good.. If the frame is missing, then obviously you will be in the market for a used frame preferably with glass to slide into the body/window frame. More details= more help.
Jason
streamahead is offline   Reply With Quote
Old 05-27-2013, 02:41 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
if the frame of the window glass is missing but the frame in the trailer has not been damaged I would consider making a plexiglass window and mounting hinges directly through the plexi. You should be able to find a auto window glass gasket in any restoration shop that will go on the frame and seal to the plexi.
I had to replace my glass with plexi after I put the handle bars of my bike through the glass. Jacking the frame apart to put the plexi in was a job. I had to make a jacking jig to do that.
2004 Excursion 4x4
Old 05-27-2013, 03:32 PM   #4
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
1956 22' Flying Cloud
Rutherford Co. , North Carolina
regular glass will fit in this frame. the glass shop or big box store will have it. it's not the exact same width, i believe its a 1/16 or 1/32 thicker. you can have it tempered if you prefer, but if its a rear window, i'd go with straight glass. the glass should be under $20. if you need the frame etc vinstream.com has one.
'57 Overlander | '56 Flying Cloud | '51 Spartanette
NJtoNC is offline   Reply With Quote
Old 05-27-2013, 03:53 PM   #5
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
My 1963 came with normal window glass in it. You could put back the same, since it is just a square cut flat glass without radius's on the corners. Here is hoping the movable window frame still exists. That is the hard part to get.
Old 05-27-2013, 04:37 PM   #6
McGraw , New York
The frame to the window itself is gone, but the frame to the opening is still there with that half of the hinge piece. I am hoping to find a frame to match up. Also will need the cranks and latches.
Steve
