Old 08-03-2019, 09:19 AM   #1
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Rear Window Removal with Streetside Awning?
Have removed, cleaned, and replaced gaskets on the curbside of our "74" Tradewind with no issues. Now on to the street side. The awning is low enough that I can't get the window up past 90 degrees to remove from the track. Any suggestions? Do I need to disconnect the awning arms, release tension, and go from there? If so, what is the proper method of pretensioning the awning arms? Thanks...
Cheers...Bob "Roadrunner"
Indiana, PA
Roadrunner is offline   Reply With Quote
Old 08-04-2019, 08:00 AM   #2
gator.bigfoot's Avatar
KW , Ontario
I disconnected the arms then carefully let the pre tensioned arm up ( better to wrap it with foam) then push the awning up about 6". Hold it in place with some stand offs. Then do your work without removing the awning.
gator.bigfoot is offline   Reply With Quote
Old 08-05-2019, 06:11 PM   #3
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Gator...thanks for the reply. Do you recall which end is tensioned? Did you let the tension all the way off?
Bob "Roadrunner"
Indiana, PA
Old 08-06-2019, 06:18 AM   #4
KW , Ontario
Bob "Roadrunner"
Indiana, PA
Left side is tensioned on mine. If you leave the awning in place you won't be able to un-tension it since the arm needs to swing all the way around. I counted 9 times on the small one I took off. The arm will swing up that's why I mentioned about wrapping it with foam (like a pool noodle). If you accidentally let go of the arm it will do damage to the skin of the trailer. If nothing else secure it by tying it down so it can't swing up too far.
Old 08-06-2019, 06:43 AM   #5
dznf0g's Avatar
Oswego , Illinois
I believe all zip dees are tensioner on left. Rear in your case for main.
-Rich-
2017 FC Streetside Big Window Replacement Too tall Windows & Screens 9 10-09-2018 02:11 PM
NEW Zip Dee 45" Window Awning for Front/Rear/Streetside Carlk Airstream Classifieds 0 09-19-2015 05:43 PM
help! looking for streetside window frame for 65 overlander Cochese 1965 - 1969 Overlander 0 06-25-2013 07:28 PM
Streetside awning azflycaster Awnings 17 06-23-2009 10:19 AM
Streetside Upper Awning Rail - Why? Cracker Awnings 14 03-18-2009 12:21 PM
