Measure, measure, measure . . .
Originally Posted by easyride
WILL THE REAR WINDOW FROM A 62 TRADEWIND WIND FIT A 63 GLOBETROTTER? i HAVEN`T PICKED UP THE GT YET,SO I CAN`T MEASURE IT? ALL HELP APPRECIATED.THANKS,DAVE
Hi Dave:
In 1962, the California and Ohio factories used different size front and rear windows, so not all trailers of a specific year used the same size rear window. Besides finding out which factory built the '62 and '63 trailers from which the windows might come, you should also measure the size of each window you are considering. I don't know how 1963 window sizes compare to the different 1962 window sizes. Measure twice and hopefully replace only once. If you can't measure, then either wait until you can or roll the dice on getting the correct size window. Hope this helps you avoid some wrong purchases.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life "From the Archives"
