Old 04-29-2009, 02:41 PM   #1
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Rear window for '63 Globetrotter
WILL THE REAR WINDOW FROM A 62 TRADEWIND WIND FIT A 63 GLOBETROTTER? i HAVEN`T PICKED UP THE GT YET,SO I CAN`T MEASURE IT?
ALL HELP APPRECIATED.THANKS,DAVE
easyride is offline   Reply With Quote
Old 04-29-2009, 03:41 PM   #2
Overlander & Sea's Avatar
Gulfport , Mississippi
Images: 32
The complete rear window assembly that rivets to the body on my '63 Globetrotter measures 44.5" x 23.5". Hope this helps.
Rick--Foley RV Center www.airstreamofmississippi.com
WBCCI #9275 TAC #MS-5 AIR #11800
Overlander & Sea is offline   Reply With Quote
Old 04-29-2009, 05:36 PM   #3
easyride's Avatar
1977 27' Overlander
Naples , Florida
Thanks much,I`ll see if the one on Craig`s list will fit.Dave
Old 04-29-2009, 06:41 PM   #4
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Measure, measure, measure . . .
Originally Posted by easyride View Post
WILL THE REAR WINDOW FROM A 62 TRADEWIND WIND FIT A 63 GLOBETROTTER? i HAVEN`T PICKED UP THE GT YET,SO I CAN`T MEASURE IT? ALL HELP APPRECIATED.THANKS,DAVE
Hi Dave:
In 1962, the California and Ohio factories used different size front and rear windows, so not all trailers of a specific year used the same size rear window. Besides finding out which factory built the '62 and '63 trailers from which the windows might come, you should also measure the size of each window you are considering. I don't know how 1963 window sizes compare to the different 1962 window sizes. Measure twice and hopefully replace only once. If you can't measure, then either wait until you can or roll the dice on getting the correct size window. Hope this helps you avoid some wrong purchases.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 04-29-2009, 06:55 PM   #5
easyride's Avatar
1977 27' Overlander
Naples , Florida
Hopefully Overlander & Sea has the same size as mine in the GTs, they are the same as the 62 Tradewind on craigslist.I emailed him to purchase his window. Dave
Thanks all for the info,now just need water filler ,and heater vent cover.
