Old 09-26-2011, 06:01 PM   #1
1978 Argosy 27
Lacey , Washington
Images: 8
Rear Bath Window question
I have a '78 28ft Argosy whose rear bath window gasket has finally stated it will not get water out any longer. I am looking for a replacement gasket. Does anyone have ideas to where I can look to find a replacement gasket?
jjustice
jjustice is offline   Reply With Quote
Old 12-13-2011, 08:30 PM   #2
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
jjustice
Inland RV has replacement gasket. I bought some from them and it was a perfect match.
timzog is offline   Reply With Quote
Old 12-06-2012, 06:22 AM   #3
Markeyro's Avatar
1978 Argosy 30
Muncie , Indiana
gaskets on the argosy...
Do you remember the shape/size? Also would you know anything about the door gasket / seal?
mark
Markeyro is offline   Reply With Quote
Old 12-07-2012, 08:03 AM   #4
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
D gasket
mark
The one that I used on my 1980 Caravelle (which has a lot in common with the Argosys) is the following D gasket with part number 45370. I found it at Inland RV.
Inland RV Center Inc.
Part #: 45370
I would speak directly with the people at Inland RV since they know how much you should buy and everything. Measure the size of the window and they tell you how much to get. On my Caravelle, the window gasket and the door gasket are the same thing so I just bought one long piece and cut it to size. Make sure you get the adhesive as well. I used 3M weatherstrip adhesive. Here is a link although probably not the best price: 3M Super Weatherstrip Adhesive - Adhesives - 2KVC4|8008 - Grainger Industrial Supply
Good luck and wear gloves when you apply the adhesive since it is possible to get your fingers stuck together and that stuff is a pain to get off I remember following a thread on this forum that outlined the process well when I did the gaskets on my windows but I can't remember where. You should be able to find it with a quick search.
Rear window screen pass through-pet door triterra Windows & Screens 4 07-19-2011 07:43 PM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
Front and Rear Window hinge - 1968 Randy Gates 1965 - 1969 Globetrotter 1 01-15-2011 10:05 PM
