Old 05-17-2007, 01:20 PM   #1
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
Send a message via MSN to dufferin
Re-seal top fixed window
I have read almost all the post regarding sealing a glass window to its aluminium frame and still not sure about wich product I should use.
The windoww I am talking about is the one the "top" of the overlander.
I have a leak cause the sealant between the glass and the frame is partly gone.
Should I go with bulty tape, Vulkem, Acryl-R...
What are your feedback?
I would love to say no rush as the weather in eastern canada is and there is no way to remove a window now, but I want to be ready to work on that in case the sun shows up...
Thanks.
Canadian Atlantic Unit Past President
Protect your dream from others and first yourself...
Few rolling wheels to make our planet a house.
A 1/5th of her that I own.
TAC# : QC-1
my blog
http://rvcampreview.com
dufferin is offline   Reply With Quote
Old 05-17-2007, 07:26 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Hi,
Are you talking about the outer edge of the frame where it meets the body leaking. Or, the the glass where it meets the inner edge of the window frame.
Old 05-18-2007, 04:13 AM   #3
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
Gary
leak is between glass and inner edge of the window frame.
TAC# : QC-1
my blog
Old 05-18-2007, 08:12 AM   #4
lewster's Avatar
Naples, FL , Hood River, OR
dufferin,
Acryl-R is great for sealing small openings in seams and will probably work very well in your situation. It 'wicks' into the seam and never really dries, staying soft and pliable. You can get it from the Airstream store on the web site or just Google it.
The very fine tip on the applicator works very well for those tiny seams.
Old 05-21-2007, 02:13 PM   #5
Originally Posted by dufferin
Gary
Clean the glass at the metal flange.
Install a bead of "vulkem sealer," at that junction.
Done properly, that's the permanent end to that problem.
DO NOT USE SILICONE SEALER.
Old 05-21-2007, 02:17 PM   #6
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
Thanks all of you...
I need to find vulkem now...
TAC# : QC-1
my blog
Old 05-21-2007, 02:47 PM   #7
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
See below from a previous post about finding the product in your area.
Here's a company that carries Vulkem and Sikaflex in your backyard. Maybe they will sell it to you direct.
Good luck.....
Cascade Aqua-Tech
Window latch dilemma maxandgeorgia Windows & Screens 5 05-18-2018 10:35 AM
Door Seal Types ??? Road Ruler Doors & Locks 3 09-07-2002 05:53 PM
outside window covers 83Excella Rock Guards, Segment & Window Protectors 2 06-30-2002 06:24 PM
Window Seals niftypkg Windows & Screens 0 06-14-2002 06:39 PM
Window Screen Weather Stripping ??? niftypkg Windows & Screens 0 06-03-2002 06:28 PM
