Old 06-26-2011, 08:44 PM   #1
1976 26' Argosy 26
Columbia , South Carolina
R & R Argosy wrap window
Saturday, June 25, 2011
Tools and such needed: spring loaded center punch, 5/32 Titanium drill bit, Rivet gun, 100+ small olympic rivets, Dremel Tool with: metal cutting blade, flap wheel sander, and drum sanding attachments. 1/4 inch chisel and wood shims, hammer( I used a dead blow hammer), 4 or 5 nails, Sikaflex - 221 or Vulkem sealant, ProflexRV sealant. To remove the old window I used a chisel and hammer to knock the rivet heads off. Next a nail set was used to bump the rivet out or they had to be drilled out with a 5/32 bit. I used a chisel to help insert wood shims starting at a corner until the sash peeled off. I had to remove the new window from the old skin using a center punch and a 5/32 in bit. I cleaned up both trailer frame and window sash with the flap sander. 00 coarse steel wool was also used to clean those surfaces followed by mineral spirits. Next I positioned the Window on the trailer as flush as possible and where no trailer holes were showing. I drilled guide holes at the 4 corners and inserted nails to hold the window inplace. I used painters tape and taped around the RV next to the window edge. I removed the window but left the nails. I put down appox 1/2 inch bead of ProFlex RV inside the taped area. Carefully insert the window back on the nail guides and press to the RV. Next start at the middle top corner and remove the nail and insert and install an olympic rivet. Do the same for the middle bottom nail. Drill and install rivets every other hole starting from middle top to middle bottom. Then do the same working from inside to out drilling and inserting rivets. Install 3 rivets on the top then 3 on the bottom until you finally meet in the middle at the very outside of the window. Then drill all the remaining holes and install rivets. Let dry overnight and remove tape. Use the dremel metal cutting wheel to cut all olympic rivet points off and the sanding drum to finish smoothing the rivet head. You can rent a rivet shaver from "Out of doors mart". Last tape up the top of the window to apply vulkem or sikaflex 221. You are done.. I included a finished R &R of Mark D's window and his procedure was simular to mine.
ID:	133402   Click image for larger version
ID:	133404   Click image for larger version
ID:	133407   Click image for larger version
Michael W is offline   Reply With Quote
Old 09-08-2011, 09:31 AM   #2
saburkha's Avatar
1976 Argosy 28
Tuscola , Texas
I'm about to attempt this same project. Thanks for posting this!
saburkha is offline   Reply With Quote
Old 09-08-2011, 10:51 PM   #3
1976 26' Argosy 26
Argosy widow install
good luck with your project. remember to take before and after pictures. questions always welcome
Old 09-09-2011, 02:23 AM   #4
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Great job! Where'd you find the non tinted window? I was under the impression that AS only made the tinted ones now? I hate to ask, but how much was it?
Marc
Old 09-09-2011, 07:42 AM   #5
1976 26' Argosy 26
Argosy Windows
Hi 3Ms75Argosy, I found them in the airstream classified in feb. Call Sun City RV @ 602 772-6893. Ask for jimmy at the unused salvage yard. Total Cost for the front three windows was $600 including shipping. You might try 602-272-0301 first as I think this will get you to the salvage yard. good luck
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 14 09-13-2018 08:05 PM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
'76 argosy wrap window lahrfarm Windows & Screens 2 03-19-2011 11:04 AM
1976 Argosy wrap window install Michael W Windows & Screens 0 02-28-2011 09:20 PM
