Old 03-29-2015, 04:20 PM   #1
RAH
2013 30' Flying Cloud
Cincinnati , Ohio
putting the window screen rubber back in place
Does anyone have suggestions on how I get the rubber back on the screen where it belongs. this is the window near the dinette on a FC. In order to properly get to the entire rubber gasket, I would need to remove the Ocean Shade, and then remove the wooden shelves above that. Is this advisable? from the outside you can see the corner not attached, but you're on the wrong side of the screen to do anything about it. Then going inside, I can't get to it because it's behind the Ocean Shade and the overhead shelf.
Any advice on removing the Ocean Shade or overhead shelf would be appreciated. Or if you have some great technique that avoids having to do that, even better!
Name:	dinette window v2.jpg
RAH is offline   Reply With Quote
Old 03-29-2015, 04:26 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Prime-Line Products P 7505 Screen Rolling Tool with Wood Handle and Steel Wheels - Window Dressing Hardware - Amazon.com
This is the tool used. You can get one at any hardware store.
MICHAEL
Old 03-29-2015, 04:28 PM   #3
r carl's Avatar
Lin , Ne
Here ya go.
Old 03-29-2015, 04:53 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Just a caveat... the screens are curved, if you do them flat then re-install them the screen will wrinkle. Best bet is to put it back in while in place. No clue on how to deal with your other stuff.
Aaron
WBCCI #XXXX AIR #2495
Old 03-29-2015, 06:41 PM   #5
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Screen issue
I think I would call JC before doing anything that might void any warranty. Your trailer appears to be new enough to get support from the factory without much trouble. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 04-27-2015, 06:27 PM   #6
RAH
Cincinnati , Ohio
solved with window screen rubber problem I had
For those who posted the suggestion of using a screen tool for a totally inaccessible area, your suggestion was useless but I think you knew that when you posted.
I did not relish the idea of removing the overhead locker or the ocean shade just to get at the screen. I did find a solution though. I pulled out the grey tubing that holds in the screen around half of the window. That allowed me enough access so I could work the top area in with my fingers, and complete putting the grey tubing back in place around the rest of the window.
Old 04-28-2015, 08:19 AM   #7
AWCHIEF's Avatar
Images: 33
Originally Posted by RAH View Post
For those who posted the suggestion of using a screen tool for a totally inaccessible area, your suggestion was useless but I think you knew that when you posted. w.
I am going to go out on a limb and assume that you did not mean to make such a rude and insulting post. You ask a question and it was answered. Most jobs are easier when the proper tool is used.
MICHAEL
Old 04-28-2015, 08:41 AM   #8
dznf0g's Avatar
Oswego , Illinois
Problem here is, it appears that the spline was installed in a stretched state (improper technique) as evidenced by it's tight line from side to side where it enters the frame again. If you had to stretch it to get it back in the groove, it will eventually come back out. This also happens as spline ages (years). It shrinks over time. I always roll in a few inches at a time, rolling TOWARD the previously rolled section. This puts the spline material in compression rather than tension. You can over compress too...takes some practice and experience.
-Rich-
Old 04-28-2015, 09:12 AM   #9
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
I have used a credit card with good success for the hard to reach areas...
it is hard to tell from your pic, but in mine the Ocean Air blind is held in by 2 screws, one at each end, can you access those? Maybe if you can unscrew the side causing you problems you can get in there better?
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 05-02-2015, 07:29 AM   #10
RAH
Cincinnati , Ohio
Nope. I meant it.
Old 05-02-2015, 07:38 AM   #11
DFlores's Avatar
1968 22' Safari
Nope. I meant it.
Can you say "ignore"
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 05-02-2015, 07:53 AM   #12
RAH
Cincinnati , Ohio
stretch too far
Interesting you say this...when I got to the bottom I was 6 inches short on the rubber, so I went to the hardware and bought 25 feet of the stuff (smallest package available). I attributed the shortage to the fact that I wasn't using one of those nifty tools. But it may have been stretched too far in the first place. Thanks for the advice on rolling it in...I hope to not become experienced in this going forward!
Putting a hitch on the back of an Airstream mlhenehan Hitches, Couplers & Balls 12 04-22-2013 12:36 PM
Putting a '79 screen door back on the hinges blickcd Doors & Locks 5 09-10-2011 04:11 PM
Was finally putting the floor back in and SNAP! Now I need a replacement.. WILDRTEXAS Waste Systems, Tanks & Totes 10 02-24-2010 04:26 PM
Putting black water valve back together mcair Waste Systems, Tanks & Totes 0 09-08-2009 01:33 PM
putting the belly back on augier Ribs, Skins & Rivets 4 01-29-2009 12:46 PM
