Old 10-30-2004, 11:23 AM   #1
Bluegirl's Avatar
Thumbs up Protecting vista view shades
After removing the inside glass and all the junk between the panes this leaves the shades vulnerable to sun damage. I have used astro foil insulation to protect the shades while the trailer is traveling or in storage. Astro foil is a light bubble plastic covered with tin foil. It is light and easy to cut. Looks good from the outside. Most home building stores carry it. Hope this idea will save others problems with their shades before it's to late.
Bluegirl is offline   Reply With Quote
Old 10-30-2004, 06:54 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Why protect the shades If you mean the ones that slide up and down, mine are silver on the backside and are made out of the same material as the inside walls. A vinyl faced aluminum panel. Now it you want to put it in there to reduce the heat build up...I am right there with you. Those shades can get HOT!
Aaron
WBCCI #XXXX AIR #2495
Old 10-31-2004, 08:55 AM   #3
Bluegirl's Avatar
Guess AS must have changed the composition as my 1976 Int. has a brown cardboard like material as a backing. It dosen't look like it would last to long unprotected. Lucky for you not so lucky for me.
Aaron
1973 Vista View Restoration Tripp Windows & Screens 12 11-17-2011 12:11 AM
vista view windows tracker Windows & Screens 2 10-02-2004 01:24 PM
Vista View Shades JohnG Windows & Screens 21 08-01-2004 09:29 PM
Vista View Shade Replacemnt John Sims Upholstery, Blinds, Walls & Interior Finishes 2 09-07-2003 04:32 PM
