Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 01-12-2013, 09:00 AM   #1
Scotman's Avatar
1986 25' Sovereign
Lake Alfred , Florida
Procedure for removing a window?
I have a 1986 25' Sovereign. I want replace all the window gaskets. It looks like the best way to do this is to remove the window. There are two rivets in the rain gutter above each window that attach to small metal pieces that each bookend the hinge. I'm guessing that these pieces somehow hold the hinge in place and that I need to drill out the rivets, slide these pieces away from the hinge (or remove them). Then I can tilt the window and hinge out of its track. Do I have that right?
Scott
Scotman is offline   Reply With Quote
Old 01-12-2013, 09:04 AM   #2
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
Don't drill until you send a picture.
That window should just tilt up to a hyper-open position, then lift out.
Please send a picture.
Ken L
2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 01-12-2013, 10:12 AM   #3
Zeppelinium's Avatar
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake , Colorado
Remove the arms from the window so you can tilt it up about 165 degrees, towards vertical, and the hinge will separate. Do not drill. Be ready to support the weight of the window as it separates.
Keep track of which window goes in which frame. They are not always identical.
Zep
Zep@Charmedquark.net
Old 01-12-2013, 10:24 AM   #4
Scotman's Avatar
1986 25' Sovereign
Thanks guys! The more I thought about it I figured I might just need to just disconnect the arms and hyper-tilt it as Zeppelinium suggested. I appreciate the help!
Scott
