Old 12-03-2013, 07:29 PM   #1
Central , Mississippi
Polisher 1, Window 0
I just finished making a replacement HEHR window and thought I'd hit the bench polisher real quick.
That didn't take long to ball up the entire frame when the polisher grabbed it. At least it wasn't a vintage unit, I can build another.
Be careful if you are gonna try to bench polish one of these things.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 12-03-2013, 07:49 PM   #2
1972 Travelux Princess 25
Cobourg , Ontario
Be careful is right, and always have the wheel going off the surface over the edge, never toward the edge. It can catch and ruin your part in an eye blink and might even throw it across the shop.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 12-03-2013, 08:20 PM   #3
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Ouch I feel for you. That's totally something I would do....
Silverflames is offline   Reply With Quote
Old 12-03-2013, 08:51 PM   #4
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I tried the bench polisher once......that was it....it flung whatever I was polishing (can't remember--I block trauma out of my mind!) Sorry about your window--what a bummer! At least it didn't decapitate you!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 12-03-2013, 09:06 PM   #5
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
1956 22' Flying Cloud
Rutherford Co. , North Carolina
1st - wheres the thread on this replica window? I wanna see!
2nd - this does not belong to a 91 or a 63...
'57 Overlander | '56 Flying Cloud | '51 Spartanette
NJtoNC is offline   Reply With Quote
Old 12-04-2013, 08:36 PM   #6
Well, you are correct, it isn't for a 91 or a 63. I'm helping out a friend with a '55 and one window was missing.
Here is how a window starts life. Figuring out the blank is 1/2 the challenge, the bend sequence is super critical.
Old 12-04-2013, 08:43 PM   #7
reinergirl's Avatar
Hollis , New Hampshire
I need friends like you! Nice work... The window, not the polishing job
I've had that moment when I was polishing on of my overhead lights
Thankfully nothing Aerowood's roller couldn't get out
reinergirl is offline   Reply With Quote
Old 12-04-2013, 09:02 PM   #8
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
id love to see more pics of the stages of the window. How will you replace the opening hardware? Will the window be fixed?
Old 12-05-2013, 12:30 PM   #9
Here are a few shots of the forming, as you can see I went ahead and made 2 frames...
I really only need the portion that opens on this project. I now will make the brackets that hold in the glass and cut out the opening for the glass. This will be for a crank open window and I'm still figgerin' up the center bar. The OEM versions use an extrusion that is NLA, I may mill one from bar stock. I have not been able to recreate the rolled hinge so a hidden piano hinge may have to be used.
For kicks and giggles I might go ahead and build the stationary frame for the spare window part that I just bent up.
ID:	201270   Click image for larger version
Name:	Standard formed.jpg
Old 12-05-2013, 06:12 PM   #10
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
Neat-o. will you please post more as you proceed?
Old 12-05-2013, 06:17 PM   #11
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Wow! I wish I had that capability.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 12-05-2013, 06:44 PM   #12
I cut out the opening with a nibbler and guide. It's an ugly way to do it but the best I have. A big file followed by scotch brite pads hides all of the ugly.
A few more steps and we will be ready to install it.
ID:	201303   Click image for larger version
ID:	201305   Click image for larger version
Old 12-05-2013, 06:56 PM   #13
1969 29' Ambassador
Very impressive!!
Old 12-06-2013, 09:35 AM   #14
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Nice work, I made a couple of those mid sixties hatches. It was fun. I also tried to make the rolled hinge also but was unable to do so. I believe they are roll formed. Nice brake
