Old 12-26-2010, 09:38 PM   #1
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Polished front window screen frame.
The old painted white, corroded window screen frames had to go. Here are the before pics.
ID:	118010Click image for larger version
I removed the paint with some paint remover. It took about three coats and four hours. I washed it up and began sanding. First I used a 120 grit 3M Rolock abrasive disk. Then I used 3M wet or dry Aluminum Oxide 320, 400, 800, 1000. I first soaked the paper in water for 15 min. I then used a cotton wheel buffer on my DeWalt cordless drill and Met-All polish. Here are the results.
ID:	118012Click image for larger version
ID:	118013Click image for larger version
ID:	118014Click image for larger version
Now there are seven more screen frames to strip and polish like this one...
Lance
Top is offline   Reply With Quote
Old 12-26-2010, 09:39 PM   #2
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
Nice work! They look great!
Get involved and sign up for a Rally!
http://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Old 12-26-2010, 09:50 PM   #3
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Thank You!
Lance
Old 12-26-2010, 10:04 PM   #4
ASwifey's Avatar
2010 30' Flying Cloud
Bakersfield , California
Wow, totally worth the effort.
ASwifey is offline   Reply With Quote
Old 12-26-2010, 10:30 PM   #5
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Thanks! It's nice to know that others think it's worth the effort
Lance
Old 12-27-2010, 08:21 AM   #6
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
That is really NICE! Be careful, however, because that polishing is addictive.
Old 12-27-2010, 09:17 AM   #7
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
It's a lot of effort, but it makes a lot of "shine" in the trailer. Beautiful work.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 12-27-2010, 09:25 AM   #8
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Looks great! I did this for the screen frame in my kitchen. Didn't polish it to a brilliant shine like yours. Just stripped off the paint and used fine grit sand paper to give it a brushed aluminum look.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 12-27-2010, 09:27 AM   #9
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Really nice work! After you stripped the frame of paint were you down to bare allum.?
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 12-27-2010, 10:15 AM   #10
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Melody-I'm an addict
Kevin-Mike- Thanks
Tim- After the paint was removed it's bare AL. It is some kind of paint though. It was really stuck on there. My frames are pitted, so it took a bit of work.
Lance
polish, screen
'67 Front window screen frame replacement SlvrSt8Steve Windows & Screens 10 11-30-2014 10:32 PM
'solar screen' replacement window screen NJtoNC Windows & Screens 3 06-23-2010 03:56 PM
I need of a 42.5" x 21.5" front window frame for '65 Overlander jeffreez Windows & Screens 0 04-16-2009 10:25 AM
Looking for front window frame- '63 Globe Trotter my63gt Windows & Screens 3 07-12-2005 08:52 PM
