Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 02-13-2016, 03:43 PM   #1
1970 23' Safari
Elkhart , Indiana
plexiglass to temporarily fix window?
So I'm new to airstreams. And I got my first one last month. The curb side vista view window was busted out. I though it would be easy to find one. Turns out I can't locate ONE. It's 32.5 x 9.5 located below the normal window next to the door. If anyone reads this and can find one that would be awesome. Anyways.
It's currently duct taped shut. Wondering if I could use plexiglass to temporarily replace it by taking out the interior molding piece and using silicone the outside.
Or take the frame out. Find a local glass company to make one for me? And reinstall it myself? I prefur to get a whole new one but it's not looking promising. Any advice would help.
Thill_1985 is offline   Reply With Quote
Old 02-13-2016, 03:56 PM   #2
cameront120's Avatar
1972 25' Tradewind
North Vancouver , British Columbia
Check here and scroll down to see if they have the width you need:
http://airstreamsupply.com/New-Airst...ware-1969-1974
North Vancouver, BC
cameront120 is offline   Reply With Quote
Old 02-13-2016, 03:56 PM   #3
Remember, Safety Third
Jim & Susan's Avatar
Catfish Corners , Georgia
Originally Posted by Thill_1985 View Post
.......Or take the frame out. Find a local glass company to make one for me? And reinstall it myself? I prefur to get a whole new one but it's not looking promising. Any advice would help.
The local glass company idea could definitely work. I accidentally broke a window while trying to take it apart. I replaced it with UV resistant Lexan. It may not last as long as glass, but may be cheaper than a custom made automotive safety glass replacement.
Solve for X, Or is it Y?
www.nesa.org
Air No. 6427
Jim & Susan is offline   Reply With Quote
Old 02-13-2016, 03:58 PM   #4
1972 25' Tradewind
Also, read up on sealants. Most of the common ones used are polyurethane (Sikaflex or Trempro). Silicon and aluminum don't play well together.
North Vancouver, BC
Old 02-13-2016, 04:20 PM   #5
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Out Door Mart appear to have what you want as well
http://odmrv.com/catalog/index.php?m...oducts_id=1040
martin300662 is online now   Reply With Quote
Old 02-13-2016, 06:05 PM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
You would be better off using UV resistant Lexan (polycarbonate) than Plexiglass. It is easier to work with and does not yellow from UV. This window does not have a problem with the wind. It could be a permanent and certainly a cheaper repair.
Is this a upper (curved) or lower (flat) window? I may have one.
Check Colaws in Missouri and Vintage Trailer Supply.
Old 02-13-2016, 08:20 PM   #7
1970 23' Safari
Elkhart , Indiana
It's the lower one
Thanks for the info. Yes it's the lower one.
Old 02-14-2016, 03:06 PM   #8
dcasr's Avatar
1990 29' Excella
Travelers Rest , South Carolina
I would suggest trying hard to get the exact replacement glass window from one of these vintage suppliers, and only going with Lexan or plexiglass as a last resort. Yes the latter two may be less expensive, but you are fixing an Airstream, and doing it right is always the best approach.
WBCCI 2456 Georgia Unit 32
1990 Excella 29' Centramatics
2016 GMC Sierra Crew Cab 2500 HD 4x4
6.6L Duramax + Allison, 3.73 axles
dcasr is offline   Reply With Quote
Old 02-14-2016, 05:06 PM   #9
3wd67rg's Avatar
1988 32.5' Airstream 325
WhereIam , Left Coast Proud
My boyfriend bought plexiglass and cut, heat, then bent it, to make a passenger window for our 1988 Classic Airstream Moho. Finding one was difficult to impossible and far too expensive, ($750 from the guy who did and then didn't have it). My Chris did an excellent job, you cannot tell it is different from the other windows except close up.
I just found the photos that show the process, 27 of them, so I don't think I will post. I will post the last one so you can see how it looks.
Your window will require more bending than this, if you haven't done anything like it before, have a professional do it for you.
3wd67rg is offline   Reply With Quote
Is there a fix for Frosted plexiglass polarlyse Windows & Screens 0 07-10-2011 10:06 AM
Temporarily fulltiming in Albuquerque Jan-June flmgrip Full-Timing, Winter Living & Workamping 8 01-04-2010 08:35 PM
Airstream production temporarily halted kamadeca Airstream "In the News" 44 11-21-2008 11:06 PM
Pulling out the pantry (temporarily) eheffa 2008 Safari SE 4 07-28-2008 07:35 AM
Temporarily Airstream-less FordTruck On The Road... 11 01-02-2008 09:49 AM
