Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 07-22-2009, 07:37 AM   #1
Profile:  1965 20' Globetrotter
New Braunfels , Texas
Plastic Moulding/Trim on Outside of Windows
In our 65' Globetrotter I have decided to replace the plastic trim/moulding on the outside of the windows. I don't know the official name for this trim, but I do know that itis gray. I also managed to get replacement moulding from a local glass shop.
My question is about the functionality of the moulding (what does it do beside asthetics) and how to cut the corners (i.e. 45 degree or leave them square/blunt which doesn't look as good in my opinion).
Finally, if I am replacing this moulding/trim, is there anything else I need to do in conjunction with this process? All of my glass is in good shape for what its worth. From what I can tell, the moulding is very brittle due to the many years in the sun, but the caulking/weatherstrip underneath is in pretty good shape. I have Vulkeim and Parbond in case I find any problems though once the trim comes off!
Thanks in advance!
Skycop is offline   Reply With Quote
Old 07-22-2009, 07:52 AM   #2
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 156
PLastic Moulding/Trim on Outside of Windows
Greetings Skycop!
The exterior glazing strips have been mitered in most of the applications that I have seen. In the 1990s, the usual direction was to use a "dab" of Vulcem on the mitered joints to improve the seal. To insure that the windows are fully sealed, you may want to consider removing the glass and replacing glazing bedding strips as well. This would also pose a good opportunity to replace the window gaskets as well to eliminate that as a possible source of leaks.
Good luck with your project!
Kevin
Kevin D. Allen
AIR #827
Old 07-22-2009, 10:09 AM   #3
Commercial Vendor
Profile:  Corona , California
Thanks in advance!
The original window gasket was very thin and hollow.
The problem with it from day one, is when the window is closed for a few weeks, that hollow gasket collapses and becomes useless.
A much improved "D" shape gasket has now been in use for several years, that has proven to be the "fix".
Thoiusands of owners have switched to it.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 07-23-2009, 03:55 PM   #4
Thanks guys...and midor....that was the word I was looking for!
7/8 plastic tee moulding glacierrunne Upholstery, Blinds, Walls & Interior Finishes 7 05-03-2007 11:22 AM
7/8 plastic tee moulding glacierrunne General Interior Topics 4 10-15-2006 09:15 PM
Source for moulding trim gaylejoe General Interior Topics 4 09-16-2006 02:39 PM
Plastic moulding Cochese Sinks, Showers & Toilets 2 06-20-2006 07:25 PM
Vinyl/plastic Trim Around The Inside Of Windows Tim T Parts Archive 8 10-21-2003 04:02 PM
