Old 09-11-2008, 06:23 PM   #15
1966 26' Overlander
Conover , Ohio
work in progress
Thanks Drummer, I pounded one of my parts flat to get a pattern, then used a bench vise and anything else it took to get the bends I needed. I am working on a jig so I can make all the bends at the proper points easily. I picked up two different types of spring steel from a local machine shop (I think he felt sorry for me). The first one was too brittle and snapped when I went to make the 90 degree bend on the end of the part. The annealed steel must be a bit softer and more formable because it worked great. This part is basically a spring if you watch how it works. Any other steel would just bend and give up. And I do have a friend at a machine shop working on the screw part as well.
Silver!! Is America going to beat a path to my door?? I better sweep the front hall, LOL
TomE
air66stream is offline   Reply With Quote
Old 09-11-2008, 06:50 PM   #16
till's Avatar
Lisle , Illinois
Images: 108
TomE,
I'll take 9
Thank you,
Tedd : o )
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 10-24-2008, 11:40 AM   #17
Vintage Trailer Supply
VintageRV's Avatar
1956 22' Caravanner
Montpelier , Vermont
Smile
We hope to have complete reproduction Phillips sill latches available late this winter. We have had all pieces redrafted and are currently working with one of our favorite manufacturers to get pricing. If anyone has already produced one of the components, please let me know so we can determine whether it would be more cost-effective to skip that part of the assembly. I can be reached at the office at 800-644-4620 x2.
Steve Hingtgen
WBCCI #1573
VintageRV is offline   Reply With Quote
Old 06-07-2009, 12:09 PM   #18
1965 17' Caravel
Creston , Iowa
window latches for my 66 caravel
Did any one successfully repop he screw part of the winow locks on the phillips locks ,,,I see a couple of you said you might be able to make them last winter .. thanks
rook440 is offline   Reply With Quote
Old 06-08-2009, 08:27 AM   #19
VintageRV's Avatar
1956 22' Caravanner
We are a couple months away, still. But we are definitely doing this project. We'll post a message here as soon as they are ready. It will be the entire mechanism and will look and operate very much like the original.
Steve Hingtgen
WBCCI #1573
Old 06-08-2009, 09:54 AM   #20
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Thanks Vintage RV. I'll be looking forward to this.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 06-08-2009, 10:04 AM   #21
GR8DANE's Avatar
1966 22' Safari
1964 24' Tradewind
1956 18' "Footer"
Southern , Minnesota
What is the best way to clean up and lubricate the original parts? I have all the mechanisms off and would like to restore them to looking and operating as new.
Thanks in advance!
life is too short to drink cheap beer...unless that's all we've got and then pass me a cold one!
Steve "Dancin" Hansen
TAC MN-31
visit my almost yearly blog http://www.bluessafari.blogspot.com
GR8DANE is offline   Reply With Quote
Old 06-08-2009, 02:22 PM   #22
flyrc's Avatar
1962 22' Flying Cloud
Yakima , Washington
Phillips draw latches
For all of you that are still looking for these, Kevin Barnes in BC has some left from a 66 he parted. I think he still has them listed in the classifieds. If not he has a Craig's list add for a 59 Avion for sale and you can contact him that way. Have a great day
flyrc is offline   Reply With Quote
Old 06-15-2009, 11:34 AM   #23
VintageRV's Avatar
1956 22' Caravanner
Thanks in advance!
Hi Gr8dane,
You can clean them with soap and water. The two parts that fall apart the most are the spring metal latch that extends and retracts when you crank, and the cross dowel that the screw threads through. If those are both in good condition, I would probably use a light tool oil on the cross dowel. you can spray paint the spring latch, but it may wear or flake off eventually. The most important thing is to just keep them clean. Salt and/or standing water are the killers on them.
Steve
Steve Hingtgen
WBCCI #1573
Old 07-31-2009, 07:37 PM   #24
airstreamjudy's Avatar
1968 24' Tradewind
Largo , Florida
Steve, do you have the window latches yet - I need a few. Please let me know when you acquire the little buggers. Judy
JudyW
airstreamjudy is offline   Reply With Quote
Old 08-03-2009, 09:00 AM   #25
VintageRV's Avatar
1956 22' Caravanner
Red face
Unfortunately, we still don't have them. Give us a couple more months. Sorry for the delay. Sometimes, doing these reproductions is slower than we expect. Lots of little things get in the way (including adding another daughter to the family!). I'll let folks know when they are finally ready.
Steve Hingtgen
WBCCI #1573
Old 11-27-2009, 10:20 AM   #26
flyrc's Avatar
Yakima , Washington
Thanks in advance!
I soda blasted mine and then polished the top of the slide plate and the inside of the curve with my Dremel tool, so it all slides with ease. Then a light coat of white grease.
I've also tried cleaning them with the mag wheel cleaner that says "etching" on the bottle. If you use the mag wheel cleaner don't leave it on to long The most important thing I've found is that any part of the latch that slides on another part must be shiny and clean.
I have 4 or 5 that will work but aren't excellent.
Wally H.
Parts needed
1962 Street side corner tub
range or parts
Dometic 50 or parts
Old 08-15-2011, 08:13 PM   #27
mgcarma's Avatar
1968 26' Overlander
culpeper , Virginia
anyone have an update on these window mechanisms yet?
thanks
Kevin
mgcarma is offline   Reply With Quote
Old 08-22-2011, 07:30 AM   #28
VintageRV's Avatar
1956 22' Caravanner
Hi Kevin,
2 years ago I said "give me a couple months." I'm sorry to report this project fell apart and I will have to restart.
The company I was working with completed samples that looked pretty good but the zinc plate on the spring metal steel wasn't acceptable. Spring steel rusts very easily...even just sitting around for a short time in humid environments. It rusted just a little before plating so the zinc didn't look smooth. There were other issues with the company's reliability, too. I'm pretty picky so I pulled the plug.
I'm going to restart the project with a new manufacturer and this time do galvanized on that part. Zinc galvanization is many times thicker than a simple zinc plate. I've got a lot of faith in my new manufacturer but I'll need more time to get it all together. If anyone else makes some nice parts in the meantime, let me know so I can work on something else.
I can't give you a firm timeline right now but I'm hoping to have it done this winter.
Thanks for everyone's ongoing support,
Steve
Steve Hingtgen
WBCCI #1573
Awning Hardware monocoque Awnings 14 05-04-2008 06:57 PM
Cabinet Hardware jfowler218 Cabinets, Counter Tops & Furnishings 0 07-27-2004 05:30 PM
Awning Hardware gwteale General Motorhome Topics 2 06-22-2004 09:47 AM
1959 Window Hardware Over59 Windows & Screens 5 05-27-2004 04:08 PM
