Old 04-28-2010, 09:16 PM   #1
1966 24' Tradewind
portland , Oregon
Smile Philips window latch
Hello again,
I removed all the window latches, a few of them had some surface rust. Anyway, I sandblasted everything. Does anyone know if they were painted originally & are they stainless steel?
Also I am trying to clean up all the window framing that is aluminum. What is the best cleaner for removing all the mildew & slight oxidation
Thanks for your help,
steverad is offline   Reply With Quote
Old 04-28-2010, 09:30 PM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Originally Posted by steverad View Post
Hello again,
Hi Steve, The ones on my 67 are non-painted stainless. Should be the same for the 66.
Also I am trying to clean up all the window framing that is aluminum. What is the best cleaner for removing all the mildew & slight oxidation.
I used 0000 steal wool and Mothers aluminum polish and the frames cleaned up very nice. IMO
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 04-28-2010, 09:38 PM   #3
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Philips latches
Steverad, The crank handles are pot aluminum, the body of the latch is stainless steel, the catch itself is spring steel and was blued originally. The barrel nut and threaded shaft are brass. The only part that has rust issues is the spring steel catch and the old spring steel clip on the glass. The new clips that are sold by VintageTrailerSupply.com and InlandRV.com are now made of stainless. I used a good mold/mildew remover on my window frames and the used aluminum cleaner followed by aluminum polish and my frames look great! Steve at VTS was supposed to be having new hardware for the window latches manufactured. I have not been looking recently as work has kept me busy. Hope this helps. Happy Trails, Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 04-29-2010, 11:28 AM   #4
1966 24' Tradewind
portland , Oregon
Thank you guys, I love this sit & the forums. I have got so much good info from here.
Window Latch Assembly (window locks) Sue&Von Windows & Screens 17 02-10-2009 06:32 PM
Window Latch phoney 1966 Overlander 2 11-10-2008 10:07 PM
need window latch help rvlover Classic Motorhomes 2 03-21-2007 11:40 AM
