Originally Posted by willyd
On my 1986, the levers to open the windows don't seem to operate correctly. The glass is not sticking to the gaskets but the levers to open the windows seem to be "notchy". Is there a lubricant or adjustment that may be necessary? Thanks in advance for your comments.
All opening window hardware and gaskets, should be generously lubed with "silicone spray." Same is true for the entrance door, and access compartment doors. While your at it, lube the entrance door lock striker bolt, and the striker pocket.
Depending where you live, that lubing should take place once or twice a year.
After a couple of days, wipe the surplus silicone spray off with a cotton rag.
