Old 08-05-2014, 03:39 PM   #1
2014 23' Flying Cloud
Salida , Colorado
Opening the windows from the inside
Hi friends: I have a terrible time opening the windows from the inside with those black pull knobs - is there a secret??? They are hard to pull up and get set in the slot. Any suggestions? Thanks, Kathy
vakathy is offline   Reply With Quote
Old 08-05-2014, 03:47 PM   #2
Tincampers's Avatar
Sneedville , Tennessee
Are the windows stuck closed? If so, go outside and take a credit card and carefully run it between the glass and the rubber strip. That should free it up.
Tincampers is offline   Reply With Quote
Old 08-05-2014, 08:50 PM   #3
2016 30' Classic
Erie , Colorado
And after you get them freed up make sure to coat the rubber window seal on a regular basis. I use pure silicone every few months. They will still occasionally stick.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 08-05-2014, 09:02 PM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The big ones can be heavy and hard to handle. Might be easier to just unlatch them, then go outside and lift the window with one hand and place the supports with the other. Yes do use silicone or 303 UV Protectant on the rubber seals or they can "bond" to the glass. Note also the latches are adjustable, should be snug enough to keep wind-driven water out but not overly tight so they are hard to use or stress the glass and seals.
Doug and Cheryl
Old 08-05-2014, 09:14 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
+1 on the 303 stuff! Pry carefully. On e the window begins to separate from gasket, do not rush. Clean gasket and window glass. Apply lube and smooth without without leaving globs.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-05-2014, 10:14 PM   #6
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
I have cleaned mine and used 303 and my Windows still stick badly, even the next day. grrrr
SSquared is offline   Reply With Quote
Old 08-06-2014, 03:13 AM   #7
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Mine are clean and lubed but I agree, the bigger windows are hard to open with those little black handles because of a lack of leverage. I find it easier to just open them from outside, especially the big one at the dining table.
Larry
lsbrodsky is offline   Reply With Quote
Old 08-06-2014, 08:50 AM   #8
2010 27' FB Classic
N/A , Texas
Larry
I do the same and use the help of a wooden popsicle stick between the window and rubber gasket to break the bond.
Old 08-09-2014, 03:34 PM   #9
2008 27' Safari FB SE
Danville , California
When we first got our AS my wife decided to open one of the side windows on our 2008 27FB. She apparently torqued one side of the black knobs more than the other....Bingo! the window shattered. She now grabs the knobs while I gently lift the window from the outside. Team work, problem solved!
tkb2041 is offline   Reply With Quote
1978 opening side windows - any remove and replace videos? drboyd Windows & Screens 1 11-10-2012 07:40 PM
Opening Windows susans69 Windows & Screens 7 02-19-2012 09:24 AM
Difficulty opening windows RV H-D Lady Windows & Screens 13 12-08-2010 05:43 AM
Operating question - opening windows willyd Windows & Screens 4 08-02-2008 10:16 AM
Windows, windows, windows... Balquin Windows & Screens 4 07-04-2006 06:35 PM
