You don't need to remove any windows from a 65 in order to replace the window gaskets using the upgraded "D" gasket, which is far superior to the original bulb gasket.
I had to remove anyway to clean up the corrosion on the frames.Can the glazing strips be replaced easily while windows are on?I did use the D gasket I got from Inland a few months ago and it is sealing tightly.However,When I ordered it I bought an extra 10 ft. in case I needed it.I checked the waste and it was only about 18in.I have 1ft. left and still 2 windows not done.
