Old 12-17-2012, 05:56 PM   #1
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
Newbie wants to know...why won't egress window work like the rest?
I am a newbie, with a 2006 19' Bambi. I camp mostly without hookups and want to know why the egress window does not open like the rest? There is a lovely screen, nice latches, even fittings on the glass for some sort of hardware, but it is just not set like the other two. This window would provide a wonderful cross breeze on a hot day. I am thinking the inside of an AS could get a tad warm in the Summer. Thanks for answer and suggestions. Sbb
Sbb is offline   Reply With Quote
Old 12-17-2012, 06:00 PM   #2
2008 19' Bambi
Windcrest , Texas
I have an 08 Bambi and mine is the same way. I guess it is dedicated as an escape hatch only. I don't really miss it with the fans in the roof and the other windows that actually do work.
Silver Dolla is offline   Reply With Quote
Old 12-17-2012, 06:41 PM   #3
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Beside what good would a window that opens be if you actually had to escape?
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 12-17-2012, 06:42 PM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Just prop it open with a stick.
doug k
Old 12-17-2012, 07:38 PM   #5
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
doug k
That's what we do...works OK...as I pointed out in another thread...don't prop it open too far ... so that if it falls closed unintentionally, it doesn't break. (We prop ours open about 4-5 inches.) You have to prop it open from the outside.
TB & Greg and Abbey Schnauzer
#3954
Old 12-17-2012, 09:10 PM   #6
Silver Baby Bambi
2005 19' International CCD
saint petersbyrg , Florida
I have a 2005 bambi and i use a j hook for hanging clothing on slat wall with a suction cup attached to one end.. Perfect angle to prop open window and the cup holds the window if it gets windy. In case of emergency just bail out!
stang2002 is offline   Reply With Quote
Old 03-22-2013, 04:28 PM   #7
2010 20' Flying Cloud
Fremont , California
Escape Window Fix
I made my own fix. I've tried to attach a photo (?) I got some aluminum sheet metal and a half-inch-wide bar from the hardware store. I drilled some holes to attach the sheet metal to the window, which, as you say, already has a couple of nuts and bolts through it. I used tin snips to cut it so it would go through the slot. I drilled some holes in the frame and made them into a slot with a hack saw blade and a file. I drilled the end of the bar and the sheetmetal end and riveted the bar to the sheet metal. I cut the saw teeth with a hack saw and filed them smooth.
There is a lot of measuring and so on. Be careful. Aluminium os soft and easy to screw up. I made two od the sheetmetal pieces before I got it right.
If you open the window far enough, the bar slips out, so you can still escape.
If you are clever you can probably do a better job than I did. I'll bet the Airstream engineers could make a nice one, if they wanted to.
Good luck.
jlight is offline   Reply With Quote
