Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 03-08-2012, 05:20 PM   #1
truckasaurus's Avatar
1960 33' Custom
Athens , Georgia
new windows on a vintage
Whilst mulling over the options available for a new layout in the Sovereign I started thinking about sourcing some additional windows. I kind of got side-tracked and wondered if anyone had tried brand new units on vintage trailer? I'm not convinced I could pull it off but it might work, even at $300 a unit.
truckasaurus is offline   Reply With Quote
Old 03-08-2012, 05:23 PM   #2
Retired.
. , At Large
I remember an Airstream owner that had much newer windows installed on her 1963 Overlander.
The Vista View and stack windows were available in 1968 or so trailers, and they have the same body contours as your trailer, so in theory they should work.Whether or not they will look "right" with the older flat-pane windows is another question.
Old 03-08-2012, 05:46 PM   #3
Baltimore , Maryland
I think Terry said it well Truck, sorry...
Old 03-16-2012, 10:50 PM   #4
dcole's Avatar
1964 22' Safari
Portland , Oregon
Thinking along the same lines
I was also thinking of replacing a couple of windows. I have a 1964 Safari with jalousie windows. Most of the panes in one of them have been replaced with warped plexiglass, leaving huge gaps plus a broken opener. I'm not a fan of these windows here in Oregon. They let too much airflow through.
The most practical thing(in terms of time and money) is probably just to repair them and live with their shortcomings.
I'm curious if anyone could share an experience of replacing jalousie windows with a solid pane? From comparing my airstream to photos of other people's Safari's of the same vintage it looks like my jalousie windows are wider than solid pane windows. I understand that jalousie windows were an option, not standard. Does anyone know if the window types would be interchangable?
dcole
1964 Safari work in progress
dcole is offline   Reply With Quote
Doing full monte on my '58 Traveler Chlyman 1958 Traveler 77 06-13-2013 07:36 PM
installing 4 6 volt batteries on Safari 27 FB The Driver Electrical - Systems, Generators, Batteries & Solar 8 05-12-2012 07:08 AM
How to reseal windows 92landyacht Land Yacht/Legacy Motorhomes 8 04-03-2012 06:16 AM
New Airstreamer AirChief Member Introductions 30 03-16-2012 04:05 PM
New Curtains -- Silver of Course pattimarty Upholstery, Blinds, Walls & Interior Finishes 13 03-08-2012 10:58 AM
