Old 05-10-2005, 11:15 PM   #1
New glass
I'm doing the full monty on a 1955 overlander. A lot of the glass needs replacing so I went ahead and ordered the 50's window weatherstripping from AS Dream. I also have removed all the frames and broken glass. So, after I clean the frames I'm back to putting the windows together with new glass. My question is, do I need any sealant under the weatherstripping? The 50's mindow glass is sandwiched between the stripping and frame. Thanks.
Will
William8979 is offline   Reply With Quote
Old 05-10-2005, 11:22 PM   #2
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Will,
I'd wait until you get the new materials..Or, better yet, give em a call to see if they can tell you ahead of time if you need to order anything special for the weatherstripping.
Got any pictures of your work in progress to share?
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 05-11-2005, 06:43 AM   #3
fireflyinva's Avatar
1961 22' Safari
Vienna , Virginia
Will,
Just started doing my own windows, too. When I picked up the unit from the P.O, he indicated that the windows needed resealing. The other thing that popped out was that the window with broken operators (a known problem, fwiw) happened when they went to Florida last year. He gave me a box full of gaskets and wished me luck.
As it turns out, none of the gaskets fit the windows. Turns out there are a bunch of different window sealing systems out there. Steve at Airstream Dreams really seems to be the best expert. That's why Vern (aka, 53 Flying Cloud) is asking for pictures. We can't really help unless we see what you are dealing with. I'll be posting pictures to my blog shortly that I've made of my effort. But I don't think it will necessarily be what you will face.
By the way, the problematic window ended up entirely sealed with silicone. For us, the system is that there is a sticky strip of mastic against the frame, then the window, then a gasket that wedges it all in place. The frame I'm currently cleaning tells a story of an epic road disaster. Silicone layered in, in many colors, then the glass, then more silicone. A broken frame. Stripped operators. Bad time in FL, I'm afraid.
Mary
Our Airstream adventure continues!
Read the details at Tales of the Toaster
fireflyinva is offline   Reply With Quote
Old 05-11-2005, 08:05 AM   #4
Over59's Avatar
Putnam , Connecticut
Images: 37
Will, what are you using for replacement "glass". Many find using UV tolerant Lexan reduces worry about breakage.
Over59 is offline   Reply With Quote
Wondering what kind of glass to use for replacing all windows in 1958 Traveller williamhenshall Windows & Screens 3 08-19-2007 07:15 PM
Glass Wax InsideOut Cleaning, Stripping & Polishing 21 09-01-2003 02:31 PM
glass dealer,manufacturer ALANSD Link Archive 0 09-02-2002 07:37 AM
How to remove the glass from windows? Andy R Windows & Screens 2 06-19-2002 09:30 AM
What type of glass should be used on a 60s AS windows? Andy R Windows & Screens 1 06-19-2002 09:23 AM
