Old 03-31-2011, 12:08 PM   #1
bgordon's Avatar
Austin, TX & , Colorado
Images: 32
need window screens / metal fabrication in Austin, TX?
I'm missing two window screens on my '48 Boles Aero. One is the larger fore/aft window (33.5" long) and the other is a side window (23.5" long). I've checked around with a couple of the vintage trailer used parts dealers with no luck. It seems like a piece that wouldn't be too costly to fabricate. I'd like to get on this as the mosquitos are one their way.
Any additional thoughts on where to acquire one or a recommendations on a fabricator near Austin? Thanks
bgordon is offline   Reply With Quote
Old 03-31-2011, 12:24 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Those look like they would be easy to fabricate. I have some bronze screen....a-la Boles Aero 1940's....when you need it.
You many find some extrusion here that you can use also....
Aluminum Extrusions Warehouse - EXTRUDE - A - TRIM
Old 03-31-2011, 02:32 PM   #3
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
There is not much there, and you have one as a sample so the design work is zero. There are metal fab shops in almost every industrial park. Look one up, bring the sample and get a quote. The only problem is the low quantity, they may pass on the job for just one.... you never know.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 14 09-13-2018 08:05 PM
'58 Hehr Window - Is this the correct window operator replacement? mello mike Windows & Screens 22 10-08-2012 08:49 AM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
Need Window Screens doglickfarms Windows & Screens 7 03-23-2011 11:40 AM
