Old 03-21-2011, 08:00 PM   #1
1972 27' Overlander
hartsville , Tennessee
Need Window Screens
Can anyone tell me where I can find window screens for a 72' Overlander?
doglickfarms is offline   Reply With Quote
Old 03-21-2011, 08:16 PM   #2
Which "exact" ones?
There can be 5 different screens in your trailer.
Old 03-21-2011, 08:22 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Andy, do they vary by location around the trailer? More's info is gooder....
5 meter Langford Nahanni
Old 03-21-2011, 08:47 PM   #4
The front window has a square cornered screen.
The rear window has a round cornered screen.
Then there are (round numbers), screens that are 20 inches, 30 inches and 40 inches wide, for the side windows.
The heighth doesn't matter since they are all the same.
Old 03-22-2011, 06:37 AM   #5
1972 27' Overlander
Andy,
I need every window screen. I am renovating a 72' Overlander and I have no idea where the screens "went".
Old 03-22-2011, 12:55 PM   #6
Andy,
Unfirtunately, most screens for the older Airstreams, are no longer available.
When they were avaiable, they had a tendency to be pricey.
I would suggest that you try to locate the screens you need, from a salvage yard, some place.
I am assuming you need the metal screen frames.
Old 03-23-2011, 12:37 PM   #7
1972 27' Overlander
Andy,
Can you recommend a salvage yard? I have redone the interior in aluminum. Would screens from a newer model (having the aluminum look) work? The windows look to be the same size, but I am at a loss to find any.
Old 03-23-2011, 12:40 PM   #8
Andy,
Try "Colaws".
1-417-5482125
'58 Hehr Window - Is this the correct window operator replacement? mello mike Windows & Screens 22 10-08-2012 09:49 AM
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 13 01-05-2012 07:41 PM
1976 Argosy wrap window install Michael W Windows & Screens 0 02-28-2011 10:20 PM
Got my window out. Now what? Breadbug Windows & Screens 3 01-23-2011 08:27 PM
