Hello from NC
Did you find a replacement for your Vista window ring? I'm having the exact same issue!!
At a loss where to find one or an alternative resolution.
Thanks in advance!!!
I went to metal mart and got a piece of aluminum the same guage as the snap ring and traced a pattern and then cut it out of the aluminium piece. Lots of work to sand and grind smooth and straight but it worked and hard to tell from the others. You do need to carefully bend it a bit bigger so it will snap in. Worked for me
