Old 11-30-2011, 07:45 PM   #1
Airstream Fanatic
ND10CentCan's Avatar
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Bismarck , North Dakota
Need some parts for a window clean up
I have been searching for the right gasket to redo the windows on our 1976 Sovereign. My husband got the first window taken apart and we are not sure where to find the gasket that holds the two panes together and what other parts we may need. Anyone that has sources for materials,directions for reinstallation, or other hints for us would be most appreciated.
Sandy
ND10CentCan is offline   Reply With Quote
Old 11-30-2011, 07:47 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
What windows? If you're talking about the double-pane Vista views and wing windows, those are generally not serviceable.
Old 11-30-2011, 08:14 PM   #3
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Oh no...
I hope you are not serious! Right now the only window we have apart is the living area side window but the wing windows and the stack windows need repair as well. So does this mean we can't repair those other windows at all?
Can we get the gasket and other parts for the full size windows? Gee...please tell me we can.
Sandy
Old 11-30-2011, 09:01 PM   #4
Sandy
Sandy.
The black outside gasket has an upgrade.
However, since Airstream quit the double pane window program, that gasket, which was not available then, is still not available, and really never was.
You will have to improvise the best way that you can.
Old 11-30-2011, 09:04 PM   #5
Janie Q's Avatar
1972 25' Tradewind
Hammond , Louisiana
post photos...
Jane
Janie Q is offline   Reply With Quote
Old 12-01-2011, 04:20 PM   #6
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Rats!
Originally Posted by Inland RV Center, In View Post
Sandy.
Thanks for that information and I am disappointed it isn't available. Any suggestions on how to improvise?
Sandy
Old 12-01-2011, 04:49 PM   #7
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Is it not a Glazing Spacer? For the wing windows...
Darkspeed is offline   Reply With Quote
Old 12-01-2011, 06:32 PM   #8
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Photos of the mess
Originally Posted by Janie Q View Post
post photos...
Jane
Here are some photos of the window mess we have going on. I am getting depressed thinking about how we might not be able to fix this very easily. I should already have known nothing on these things is an easy fix. The first picture is of the entire gray gasket as it would appear around the window and the picture of my hand and the gasket. This gasket is the one we are looking for right now. It is about 1/2" wide and about 1/2"tall on one side and a 1/4" on the other side.
One the bright side, I have the two panes cleaned up pretty well and all we need now is the gasket. I hope someone out there has a couple of hundred new ones sitting in their garage they are willing to sell. Call me!
Sandy
Name:	Late November 2011 Pacer and Albatross 063.jpg
ID:	146305   Click image for larger version
Name:	Late November 2011 Pacer and Albatross 060.jpg
Name:	Late November 2011 Pacer and Albatross 054.jpg
ID:	146307   Click image for larger version
Name:	Late November 2011 Pacer and Albatross 069.jpg
Old 12-01-2011, 06:36 PM   #9
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Is that the same as the photo I just posted?
I am not sure of what they are officially called but I call the gray piece in the photo a gray gasket so maybe I am not naming it what it really is. We didn't even take a wing window apart yet. We figured we would try a large roadside living room window first and see what happened. I will do a search on glazing spacers to see what I come up with. I also plan to do a recon on local glass places tomorrow to see if they might have something that would work. I will also run around on the weekend and go to all of the local hardware stores. If it to be found, I will do my best to find it. Stay tuned.
Sandy
Old 12-02-2011, 06:51 AM   #10
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Here's a thread that may interest you:
http://www.airforums.com/forums/f454...ilm-37422.html
You can find a lot of glazing bead/channel on the internet but I was not able to locate any with different heights on the legs.
Old 12-02-2011, 12:33 PM   #11
x
XXXX , XXXX
Sandy have a look at this gasket. It may be exactly what you are looking for.
CRL Glazing Vinyl for 1/2" Sealed Insulated Glass Units - CRL INSULATING GLASS ADAPTERS AND SUPPLIES
I got the link from Zep's thread. That is the one listed above and the thread I mentioned to you in your mian thread.
wasagachris is offline   Reply With Quote
Old 12-02-2011, 07:44 PM   #12
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Excellent point
Thanks Chris,
I did look through that but for some reason wasn't sure that was exactly what we needed. I might have wasted more time than I needed to which isn't the first time nor will it be the last time. I may have to order this stuff and see if we can make it work.
I did go all around town looking for gasket today and met a very "funny" man at a local glass shop. I guess the experience was worth the entire visit to the circus and the 45 minutes of entertainment I provided to the entire glass shop. I am sure all of the men there were laughing and thinking "What a nut case!" Glad to know I can provide such a service for such a limited audience and to think so many comedians are out of work and I got to meet this hilarious character and all of his followers today.
My first clue when I asked about the above mentioned gasket was "Waddah ya want it for?" An Airstream was my reply. "A WHAT???" An Airstream. You know a camper trailer. That stopped the entire shop in its tracks and all eyes swiveled to me. "She has a WHAT?" Picture that going through about 5 guys turning to each other and repeating the same thing.
And from there it kind of went down hill. Somehow appearing in a glass shop asking about gasket material for Airstream windows is a kin to asking for the wings off of the tooth fairy. Everyone was plenty amused and proceeded to tell me how it can't be done, why would I want to try to do it, and they had never heard of anyone rebuilding windows on a camper themselves. In fact, they said they don't even do rebuilding of camper windows because the seals just don't last. The owner said "So you just like kicking your own &ss?"
In case you might be thinking this was a small shop with new people, this is actually one of the higher end glass shops in town. This is the shop that does all of the expensive showers and windows for the places in Bismarck and Mandan that I could never afford to live in. I am guessing they have seen many things but obviously, not a crazy lady with an Airstream.
It was all in good fun though because the owner did wrestle out a reel of gasket material that "has been here since he came to the shop 28 years ago and no body has ever asked for it". I took a sample piece off and I will see it if will work tomorrow. It looks too wide but time will tell. It was in good shape and still had flexibility to it so if it fits, it might be workable. I would rather not have 28 year old material though especially because we have NO intention of having to do this project again.
Ask me if I plan to go back and get the rest of the gasket material if it does work and I would say....absolutely. I am on a mission to get camping someday!
Sandy
Old 12-02-2011, 08:00 PM   #13
x
XXXX , XXXX
Sandy when I rebuilt my VV's & stack windows they had already been "worked" on so there was no gasket there anymore. I just imbeded them into Vulkem. I managed to find the right size pre-shimmed butyl tape at a local glass shop. I got lucky as it was some old stock in the back, kind of like the gasket you found.
In Zep's thread he states that the gasket was the right size and available in 100 ft rolls. The pre-shimmed tape however had to be ordered in a large quantity so I would check for that locally.
My lift up windows are different. The inner panes are easily removable. They are actually in their own seperate frames and are screwed to the outer frames.
I was able to find NOS wing windows on E-pay, so I haven't yet tried to rebuild mine. I just replaced them with the NOS ones. It took me a while to find both of them, which I had to buy from seperate sources. The first one I got I actually had to buy a pair of roadside windows to get the one. Sorry I already sold the second one.
The curbside wing window I found off the forums classifieds and I think the seller still has some left.
Old 12-02-2011, 08:21 PM   #14
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
More info is good
We may well end up ordering from this site if we can't figure out a local fix. I am not sure how much more entertainment I can provide to local vendors though .
I might end up getting some stuff off Ebay but I would much prefer spending my dollars locally if at all possible. Unfortunately, there aren't many things in the local area that work for Airstreams so we are trying to stay local but seem to be ordering most of our supplies online. At least we are doing our part to keep the economy going.
Aren't you on a plane already?
Sandy
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 13 01-05-2012 06:41 PM
Super clean 1984 Airstream w/ professional window tint eBay Watch Airstreams on eBay 0 05-01-2011 09:10 PM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
Super clean 1984 Airstream w/ professional window tint eBay Watch Airstreams on eBay 0 04-26-2011 12:20 PM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
