Old 12-19-2011, 06:28 AM   #29
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Keep up the tedious work Sandy! I took an old wing window that was gifted to me by Zep, to the biggest window shop around. After four months of nothing, it was handed back to me. The owner stated that if you can buy a new replacement, do it. It would cost twice as much in labor to disassemble, clean and reassemble the old window than just buying a new window. I do recall that, Chris had fitment issues with a new wing window and someone suggested to fill the gap with Vulkem or Sikkaflex. Probably not the look y'all are going for. Good luck!
Lance
Top is offline   Reply With Quote
Old 12-19-2011, 06:51 AM   #30
x
XXXX , XXXX
Sandy I did not have as much luck finding a replacement gasket as you did. So I chose to find NOS windows and just replace them. The first purchase I made was for two curbside wings. I had to buy two to get one. I sold the other one to Top. UPS ( United Parcel Smashers) managed to bang it up pretty good so I don't think he has used it yet. My plan was to replace the one and disassemble the old one and try to rebuild it. If I was successful then I would pull the roadside one and just rebuild it. Then I found a roadside NOS window and ended up just replacing the roadside one. I have kept both old wings and have a far distant plan to rebuild them.
When I disassembled the curbside wing I got impatient and broke off the heads on two screws so now I need to find out how I can get the shafts drilled out and retap the tiny holes in the frame. So that is why I tell you to soak it well for days in a rust buster.
If you heat the rookery you can have all the kids/ grandkids "camp" out in the Albatross for the holidays.
wasagachris is offline   Reply With Quote
Old 12-19-2011, 04:49 PM   #31
Airstream Fanatic
ND10CentCan's Avatar
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Bismarck , North Dakota
Now I am nervous...
Oh, oh....if a large window shop doesn't want to tackle these wing windows, than what are we thinking? I have not seen any replacement windows offered up so far on Ebay but maybe I don't know how to search properly. I am expecting most would be in as bad shape as ours unless we got really lucky and found NOS. I will keep my eyes open just in case....
Thanks for the info.
Sandy
ND10CentCan is offline   Reply With Quote
Old 12-19-2011, 04:54 PM   #32
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Sandy,
Don't be nervous! He just said that it wasn't economical for HIS SHOP to repair. I'm sure you can and will do great at it!
Lance
Old 12-19-2011, 06:17 PM   #33
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Stay tuned....
Sandy,
Hey Top,
When I think about some of the labor intensive, back breaking work that doing this restoration has involved so far, I think most companies would not want to think about what they would have to charge the customers. Strange thing is that I think most AS addicts take to it like a duck to water. Part of it is the challenge to try to figure things out and see if you can make something out of it. Thanks for your support and I will let you know what happens....
Sandy
Old 12-27-2011, 08:43 PM   #34
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
One down, one to go
Here are the pictures of the two wing windows on the Albatross. Two pictures show one all cleaned up and reinstalled and the other one is waiting patiently for its beauty treatment. Compare the cleaned up one to the icky one and you know how much better the fixed one looks over the original state we found it in. The additional picture is proof that my husband and son do know how to use window cleaner! All this time they told me they didn't know how to clean windows.
The worst part of doing the wing windows so far has been the fear of breaking one and a close second is the 3 inches of sticky white foam caulking around all the sides. It is quite a chore to get the window loose from that stuff so it is slow and steady as it goes. Luckily we only have one more to go.
We had to develop some inventive approaches to seal the wing window. We have a couple of lines of thin butyl tape and lots of sealant on the window. It was also interesting to buck the rivets around the window because it gets deep in a couple of places and the bar wasn't quite the right depth. Luckily my husband had a couple of left over pieces of steel frame that he modified to use in those tight spots. Necessity is the mother of invention yet again.
Sandy
Name:	December 2011 159.jpg
ID:	147699   Click image for larger version
Name:	December 2011 153.jpg
Name:	December 2011 158.jpg
ID:	147701   Click image for larger version
Name:	December 2011 162.jpg
Old 12-28-2011, 04:55 PM   #35
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Looks great Sandy! See, I told you you could do it!
Lance
Old 12-28-2011, 05:06 PM   #36
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Thanks Top!
Thanks for that compliment but it was really my dearest's accomplishment. I help but he is the brains of the operation. I did clean up the second window's frame this am so he could take it out tonight. I have this week off of school so have some time that I don't usually have. If I could figure out how to start wiring, I would be on that. That is a really scary idea I am afraid!
Sandy
Old 12-30-2011, 09:49 PM   #37
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Tonight we finished the second wing window and now all of our windows in the Albatross are DONE!! On to bigger and better things now. Hopefully the Pacer windows won't be the chore these ones were. For those of you thinking about taking this type of project on, I would suggest the following:
1. Take your time.
2. Don't intoduce rivets into the glass because something bad happens.
3. Plan to take four times as long getting it done than you originally thought.
4. Buy at least two different kinds of bucking bars and lots of sealant.
Time to celebrate by trying to find ties to hang the bundles of wiring onto the outer shell. Can't say I don't know how to have a good time!
Sandy
Old 03-18-2012, 07:02 PM   #38
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Does anyone know where to find the plastic knobs that go on the window levers on the Albatross? Some of ours are broken, some are missing, and some are just in really rough shape. They are an off white (at least I think that was the original color?!?) and are connected together with a metal screw/bolt that fits on the end of each lever that opens and shuts the windows. I am hoping there are new replacements out there and not unobtainum. Thanks for any sources anyone has.
Sandy
Old 03-18-2012, 08:17 PM   #39
Sandy
Sandy.
Sorry, but Airstream declared those round knobs for the "deluxe" window lift arms, "obsolete", many years ago.
Old 03-18-2012, 09:12 PM   #40
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Sandy,
I'm sure your local machine shop would be glad to make you some exact copies for a small fee. If you have a technical community college with a machining program nearby, that is where I'd start.
Lance
Old 03-19-2012, 05:57 AM   #41
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Rats again
Originally Posted by Inland RV Center, In View Post
Sandy.
Thanks for that info Andy,
Is there any other source that you know besides Airstream? I wonder if you could make a set with wood and the bolt. Just thinking out loud.
Sandy
Old 03-19-2012, 06:01 AM   #42
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Thanks Top
Sandy,
I might take one to work and see if anyone thinks they can make it. Then if that doesn't pan out, I will try a couple of places around town. Somehow it seems a person could start a business replicating this hard to find items. I appreciate the information and direction.
Sandy
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 13 01-05-2012 06:41 PM
Super clean 1984 Airstream w/ professional window tint eBay Watch Airstreams on eBay 0 05-01-2011 09:10 PM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
Super clean 1984 Airstream w/ professional window tint eBay Watch Airstreams on eBay 0 04-26-2011 12:20 PM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
