Old 01-18-2011, 01:21 PM   #1
Breadbug's Avatar
1969 31' Sovereign
1975 25' Tradewind
Walnut Creek , California
Need help removing rivets.
Hey there. I will try removing and replacing my wing window soon. I am worried about removing the rivets. Is there a tool that allows centered drilling? Just tap it with a awl? Best ideas? Before I go drilling rampant holes. Please?
Breadbug is offline   Reply With Quote
Old 01-18-2011, 01:29 PM   #2
Sphere Guy's Avatar
2016 30' Classic
Livingston , Texas
Rivet removal
Breadbug,
An awl or better yet a center punch or nail set or old nail will make a sufficient dimple in the rivet to allow the drill bit to track.
Sphere Guy
AIR 50601
Sphere Guy is offline   Reply With Quote
Old 01-18-2011, 01:43 PM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We used a spring loaded center punch - I found the "special-drill-out-your-rivet-tool" to be a waste of time & money. It rarely did what I thought it was supposed to do - drill a hole in the CENTER of the rivet...with a center punch, it was much easier to control.
We also were able to just hand twist the drill bit in the opposite direction a half turn or so to set it, then drill away without the need to center punch at all. A lot of our rivets had the original dimples still there so those were easy.
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 01-18-2011, 03:31 PM   #4
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
I have had 100% success with this rivet removal tool here.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 01-18-2011, 03:44 PM   #5
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
I have also used the tool Tim(ts8501) suggests. Like most tools it does a good
job if you let it. I dont think I would buy one for just a few rivets but it does
work good
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 01-18-2011, 04:16 PM   #6
Images: 59
If you get a high quality split point drill bit it will help you a lot.
Old 01-18-2011, 04:41 PM   #7
dznf0g's Avatar
Oswego , Illinois
Use the tool above. It will ensure exact centering of the bit and that way you will not enlarge the hole in the AS so the new rivet will fit tightly.
Old 01-18-2011, 04:52 PM   #8
InsideOut's Avatar
1956 22' Safari
Images: 108
That's the same tool I had...guess it must be operator error on my part, I found it to be very inaccurate.
Shari
Old 01-18-2011, 04:54 PM   #9
Breadbug's Avatar
1969 31' Sovereign
1975 25' Tradewind
Thanks everyone. I am gonna get
The tool. I'd rather try and fail than not try and fail. I wanna be as safe as can be with the exterior. I've got other panels to do on my other trailer too, sooooo.
Thanks all.
Old 01-18-2011, 04:56 PM   #10
dznf0g's Avatar
Oswego , Illinois
Shari
What happened while you were using it? Slipping off center?
Old 01-18-2011, 04:57 PM   #11
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
I also used the "Rivet Removal Tool" from Aircraft supply and it worked like a dream. I played with punches with very mixed results. Got the tool and everything worked like a snap.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 01-19-2011, 07:45 AM   #12
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Shari
Shari:
The only rivets I had problem with the tool slipping off of was some early (soft) Olympics that I replaced. The original Airstream factory rivets were no issue at all. You have the center dimple on the rivet that helps, and then I also lean some of my weight into it.
-Tim
TAC MN-6
WBCCI/VAC 11736
AIR 25979
Old 01-19-2011, 08:30 AM   #13
BradS's Avatar
1957 26' Overlander
Images: 14
After a little practice , see photo, Im finding out that I like doing it free hand. Just a drill bit in the drill. Go slow and easy
WBCCI 10289
TAC MN-69
AIR 11240
Old 01-19-2011, 10:43 AM   #14
InsideOut's Avatar
1956 22' Safari
Images: 108
Me too...looks good!!! I loved the metal working part of our project...starting around post #200. We didn't have to (get to?) do the end caps, but between our two trailers and additional help on a friend's, we have replaced 3 streetside and 2 corner panels.
Shari
Earning Rivets and such tvanwave Forum Admin, News and Member Account Info 10 06-07-2011 05:33 PM
Stainless steel screws instead of rivets? Lothlorian Ribs, Skins & Rivets 33 03-23-2011 12:22 AM
inside ceiling rivets lsrart1 Ribs, Skins & Rivets 1 01-17-2011 06:53 PM
Larger Interior Rivets? MDSilverado Ribs, Skins & Rivets 3 01-10-2011 07:54 AM
