Old 08-14-2011, 11:40 AM   #1
mgcarma's Avatar
1968 26' Overlander
culpeper , Virginia
Need a window for my '68 Overlander. Pls help
My PO replaced a broken window with plexi and it does not seal properly, which has resulted in a leak. I have a picture of it, and I will get some measurements for you all also. I have posted an ad in the "wanted" section, but I thought you may have some input on boneyards/used parts sellers here.
It is the window directly to the right of the entry door. I need the frame and glass. Thanks for your help!
Kevin
mgcarma is offline   Reply With Quote
Old 08-14-2011, 02:00 PM   #2
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
kevin
used windows are very hard to come by; in fact I just drove 1500mi round trip to buy 2 (yes I'm crazy, and yes I have heard of fed X). You can buy new from Inland RV I think that window is 17x20.5 but check that w/ Andy. The new window will be 1/8" which is a little thicker so your ss trim will not fit.
Kevin
kevinb is offline   Reply With Quote
Re-installation Rear Window Glass 1968 Overlander International Rhodo1937 Windows & Screens 17 07-17-2016 07:32 AM
'58 Hehr Window - Is this the correct window operator replacement? mello mike Windows & Screens 22 10-08-2012 08:49 AM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
