Old 07-15-2010, 09:05 AM   #1
Send a message via AIM to spaceghost65
Smile Need a Window Crank Messiah
If you can tell me where I can get a pair of these assemblies for a replacement window I ordered from Inland RV I will form a small religious group around you. More of a cult really but it's the thought that counts.
1967 Safari - Roadside front top window is the one being replaced. Have clips. but that's it, need cranks and the square housings.
Thanks to Andy at Inland RV - BTW No they haven't kicked Austin out of Texas yet. lol
Name:	2010-07-15 08.14.58.jpg
ID:	106842   Click image for larger version
Name:	2010-07-15 08.15.07.jpg
Coming soon: a crowd pleaser.
spaceghost65 is offline   Reply With Quote
Old 07-17-2010, 05:57 AM   #2
Homewrecker's Avatar
1964 22' Safari
Indianapolis , Indiana
check online and by phone, Vintage Campers. Peru, Indiana.
There's a reasonable chance they'll have two.
good luck!
Homewrecker is offline   Reply With Quote
Old 07-17-2010, 06:02 AM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I don't think they are available new or reman. You will need to check the usual sources for salvage. If I recall, there was a post a few years ago from someone who had made some for his trailer, but he had a machine shop.
Old 07-19-2010, 02:47 PM   #4
Yep, I know they can only be had as salvage parts. Thanks for the tip and the name of the business. I might just have to suck it up and attach the clips to the window casing and have it be a "non-opening" window until I can find these guys.
Old 07-19-2010, 05:48 PM   #5
1960 24' Tradewind
Riverside , California
All the large windows have three.....you need one.....middle one becomes a donor. You don't need all 3 on the front, most of them had rockguards, if not the air pressure driving will keep it shut. Different story on the back one.
Think it'll work?
Greg
1960 Tradewind
2007 Denali 6.2
2005 ST 1300 ABS
2005 Chevrolet SSR 6.0 LS2
airstreamlosangeles.com
ZoomZoom is offline   Reply With Quote
Old 07-20-2010, 03:14 PM   #6
I don't see why not. Only issue might be the window getting lopsided in the casing. Shoot I'll take 1 if i cn get any at all. No responses from anyone so far except you guys.
Old 01-16-2011, 11:24 AM   #7
1964 22' Safari
Elk Point , South Dakota
Window cranks
Sorry it took so long to respond...I work out at sea and as such am not in the loop for a month at a time.
Okay...what I can do is take a few photos of our cranks and you tell me if they are the right application for your unit. I just need to know what window you are speaking of.
Cheers,
Gypsea
Gypsea is offline   Reply With Quote
Old 01-17-2011, 08:25 AM   #8
1963 28' Ambassador
Northern VT , Vermont
Just a possibility. I found crank assemblies for my '64 safari in an old junked house trailer, don't even know the brand of the junker but they fit. It apeers they were used on more than just airstream.
putback is offline   Reply With Quote
Old 01-17-2011, 08:40 AM   #9
Silverhobby's Avatar
Greeeneville , Tennessee
Phillips Window Cranks
I am interested in seeing the window cranks you have found. If you have a picture, please post it for us.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 01-19-2011, 08:12 AM   #10
1964 22' Safari
Window cranks
Took the photos yesterday and will resize them and post here a little later...they are the type that are on the sides of all the windows.
Cheers,
Gypsea
Old 01-19-2011, 11:46 AM   #11
1964 22' Safari
Window cranks
Let's see if I can figure out this newfangled thingy called a kompyootur...
Spaceghost65...let me know if you can use these. About the only other thing I will be removing from the unit are the original propane tanks and the maybe the whip antenna. All 3 awnings are in great shape and get used in spring and summer.
ID:	119669   Click image for larger version
Old 01-19-2011, 02:16 PM   #12
aluminomad's Avatar
1968 22' Safari
Salem , Massachusetts
Think it'll work?
Greg
are you saying it's unsafe if the rear window has just the outside 2 working (middle one has no clip on window) we have a 68 safari
aluminomad is offline   Reply With Quote
Old 02-07-2011, 04:20 PM   #13
Gypsea > Not quite but if the internals are the same maybe I could retro-fit them.
I sent one along to a machine shop to see if they can recreate these. I will let you know if I am able to procure them and if anybody else needs them. I am tried of unanswered craigslist emails :/
Old 02-07-2011, 04:32 PM   #14
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Did you try Colaws RV Salvage in Missouri, Spaceghost? They carry many AS parts, and might have something for you...
Kay
Old 02-07-2011, 06:24 PM   #15
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have a pair of OEM cranks only I will sell cheap. By the way you can get a crank that fits from a RV/ trailer supply, but it will look different.
Old 03-24-2011, 08:45 AM   #16
1964 22' Safari
Sorry so long in getting back to you on this...me and the Missus have have come to terms that this unit will most likely get restored and turned into the guest house as originally planned, so ware are not going to remove any parts from it. It's a good solid roller, (just towed it from Virginia to South Dakota last year)and wish to keep what we have as far as window hardware. Good luck on your project...
Cheers,
Gypsea
window crank safari
Which window crank is this on my '64 overlander? chriscrimmin Windows & Screens 4 03-15-2010 06:29 PM
Window crank broke Devoman Windows & Screens 4 12-16-2007 01:10 PM
window crank lube Jabba Windows & Screens 7 06-08-2006 08:22 PM
Window Crank Arm removal wohtex Windows & Screens 5 04-14-2006 09:23 AM
window crank nevisstudio Windows & Screens 4 11-20-2003 02:19 PM
