Old 06-26-2011, 10:48 AM   #1
calivw78's Avatar
1969 31' Sovereign
Larkspur , Colorado
Need a quick temporary fix
We have a 69 Sovereign that we are taking to NC from CO in early July. We are attempting to putting in acrylic that we picked up from Lowes, since all the windows were missing when we bought the trailer.
The goal is to put something temporarily in place. Next off season, the plan is to put in something a bit nicer. That being said, whatever we roll with for now needs to be able to come off. Two part epoxies and all that need not apply
Here are the three items we have tried on the acrylic. For all of them, we tried on a untouched section, and a section where we roughed up the suface a little. After 24 hours, all of them seem to rub off fairly easy with a finger tip.
  1. GE Premium Waterproof Silicone GE50.08 (Window/Door/Attic/Basement)
  1. GE Premium Waterproof Silicone GE5050 (Aluminum/Metal)
  1. LOCTITE Polyurethane Sealant (Window/Door/Siding)
    Loctite PL Polyurethane Window Door and Siding Sealant from Loctite Adhesives
Does anyone have any recommendations on a Lowes/Home Depot product we can use for the time being? Or, is this type of rubbing behavior expected?
Thanks in advance.
1969 Sovereign Restoration Project
http://airstream.calivw78.com
calivw78 is offline   Reply With Quote
Old 06-26-2011, 11:24 AM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I would try aluminum tape. I taped acrylic over the window on the drivers side with al tape when we went to Alaska. Stayed on fine. Get the thin acrylic storm door glazing from lowes, cut it to fit outside the window frame, and tape it on. should work fine. the more expensive the tape, the better it works, so do not go cheap on the tape.
Rear End Separation Permanent Fix? dmand001 Repairing/Replacing Floor &/or Frame 23 07-24-2017 02:12 PM
Floor/frame separation fix - section or all at once? GlobeTrottin Repairing/Replacing Floor &/or Frame 11 05-12-2011 07:21 PM
Temporary Seal for Vista views AluminumGirl Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 01-08-2011 11:06 AM
