Old 01-18-2015, 03:17 PM   #1
1965 20' Globetrotter
Sacramento , California
Images: 13
Mottling, corrosion, oxidizing on window screens and frames
So I see on all my 50 year old window screens and frames this mottling or oxidizing mostly on the interior. I'd like to be able to remove as much of this as possible. I tried Flitz and fine steel wool, but no difference really. What would be a good technique to remove this? Thanks much.
"It's always something!" --Roseanne Roseannadanna
jakes_mama is offline   Reply With Quote
Old 01-18-2015, 08:56 PM   #2
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I'll be watching this thread to see if anyone has any other suggestions. All I can think of is some very fine-grit sand paper, or emery cloth. It would definitely be a trial and error thing, but it might work. Might even try Bar Keepers Friend | Cleaning Products | Household Cleaning Supplies
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 01-18-2015, 09:22 PM   #3
Images: 13
PaulnGina, Just found this thread--it seems like a lot of steps. But I like the pictures and the results. Bar Keepers Friend is good on a lot of things. I may try it too.
http://www.airforums.com/forums/f441...mes-48232.html
Old 01-18-2015, 09:31 PM   #4
1966 20' Globetrotter
1968 24' Tradewind
Airstream_ , Open Road
New Screens?
Have you looked into the pricing for new screens? My GlobeTrotter and Trade Wind screens both had corrosion inside the frame tubing and out and I found a professional screened patio and window repair place that had the "knife edge" window screen frame in stock. It was identical to the screen frame used in 1966-8 and the average cost was around $20 each for the six windows.
As for removing your corrosion I'd have agree with the very fine sandpaper or green scrubby idea.
Michael Rice
Full timer WBCCI #1923
1966 Airstream 20' Globe Trotter (Twin)
1968 Airstream 24' Trade Wind (with Vista Views)
Airstream_ is offline   Reply With Quote
Old 01-18-2015, 09:34 PM   #5
PaulnGina's Avatar
Good Ol' , USA
That reminds me.... I used a scotchbrite pad on my aluminium LP tanks and they cleaned up real nice. It took some elbow grease, but it worked well.
1987 Avion 34W
Old 01-18-2015, 11:12 PM   #6
Images: 13
Did you use anything with the Scotch Brite pads like water or anything? So new at all of this...thanks.
Old 01-19-2015, 05:13 AM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
just what I did.....
600 to 1200 grit wet sandpaper,(plenty of water), touched up with metal polish to shine/seal when needed...
Old 01-19-2015, 05:18 AM   #8
PaulnGina's Avatar
Good Ol' , USA
Nope, just me and the Scotch Brite pad.
1987 Avion 34W
Old 01-19-2015, 05:21 AM   #9
PaulnGina's Avatar
Good Ol' , USA
Wow. Nice results.
1987 Avion 34W
Old 01-19-2015, 05:41 AM   #10
Wow. Nice results.
Thanks...turned out pretty well. Could have been brought up to mirror but I wanted them to blend well with the skin.
Hardest part was removing the poorly applied clear....
Old 01-19-2015, 05:04 PM   #11
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
Do not use steel wool. It will imbed in to the aluminum and turn it black. Use aluminum wool. Many airplane finishes have been ruined with steel wool.
Old 01-19-2015, 06:47 PM   #12
reinergirl's Avatar
Hollis , New Hampshire
I used maroon scotch brite and wd40 , followed by grey scotch brite and more wd40. Something in that wd40 is magical !
The way I cleaned and restored my windows here ;
post 411
http://www.airforums.com/forums/f109...ml#post1359989
reinergirl is offline   Reply With Quote
Old 01-19-2015, 10:01 PM   #13
Images: 13
Oh my gosh Reinergirl that is just exactly what I needed to see (and read!). Thank you for your thread--not only informative but very entertaining as well!
Luckily I had just started with one window screen, and will try the scotch brite and WD40 on the window frames as well. Still debating if I need to remove the windows or not. I am hoping they just need some new weatherstripping and seam sealants. I will need to do the plastic gaskets too, so your description on your coping method was timely as well.
Thanks also Guskmg for the heads up on not using steel wool. I hadn't heard of that before.
Tackling a bunch of things this week. Supposed to be upper 60s to 70 by the weekend here in Northern Cal.
Old 01-20-2015, 11:03 PM   #14
GlamperGirl
Thanks for this window thread!
thumbelinadj is offline   Reply With Quote
corrosion, oxidization, window frames, window screen
Anyone know what kind and size rivets are on the window frames? deepsea27 Ribs, Skins & Rivets 11 06-15-2013 11:15 AM
What type of caulk to use to seal roof panels and window frames? grndslm General Repair Forum 2 04-20-2013 01:39 PM
Window and Screens for 1960 Ambassador rowdyATX Windows & Screens 1 02-27-2013 05:06 AM
Need Help cleaning our screens and vent screens ctalley316 Full-Timing 3 09-19-2008 11:48 AM
