Old 04-14-2013, 08:16 PM   #1
Hobo
2006 25' Safari
Florence , Oregon
More screen removal issues
My search doesn't seem to come up with an answer for this simple question. I have an 06 Safari LS and can't seem to budge the front screens to remove them. I see the wire clips on bottom and sides and I can pry them up but I can't slide the screens up or figure out how to remove them. Any help would be greatly appreciated.
voremus is offline   Reply With Quote
Old 04-23-2013, 04:24 PM   #2
2005 19' Safari
2007 23' Safari SE
Onekama , Michigan
I have an 05 Safari and I don't know if the clips are the same, but probably are. Pry the clips out cafefully. I used a slot screwdriver. The shorter the better. After cleaning the screens I found out why they were so dirty. No one had ever taken them out. Or, they did a long time ago and never did it again. The clips are a real pain to re-install. I gave up on the side clips and hope the two on the bottom of each will hold the screen. If the window would open further it wouldn't be so hard to get your hands in there. Good luck. Perhaps someone else would give us a hint that makes it easier.
gene t
Gene T is offline   Reply With Quote
Old 04-30-2013, 08:23 PM   #3
Hobo
2006 25' Safari
Florence , Oregon
Anyone??
Old 05-01-2013, 07:27 AM   #4
1981 31' Excella II
New Market , Alabama
How about a photo? I don't know about the newer trailers but the older ones have a frame that is screwed to the wall. Remove the screws and the handles for the window controls and remove the frame.
Perry
Old 05-01-2013, 08:29 AM   #5
aftermath's Avatar
Spokane , Washington
Yes, a photo would be nice.
I have an '06 25 FB and it is not outside right now. I do recall looking at the screens as one needs some attention. What I saw were screws holding it in place. The handles would have to be removed but that looked like it.
I would love to see your pictures of these "clips" that you have. Makes me want to go out to the storage lot and take a look.
aftermath is offline   Reply With Quote
