Old 06-08-2011, 07:01 PM   #1
1966 30' Sovereign
Mount clemens , Michigan
Lower window sealing
This is a 66 sovereign. What is the best way to seal these lower windows? I have acryl and parabond. The acryl will wick but will it seal? Any advice is appreciated.
ID:	132039   Click image for larger version
Brianv512 is offline   Reply With Quote
Old 06-09-2011, 11:42 AM   #2
1966 30' Sovereign
Crickets
Old 06-09-2011, 12:02 PM   #3
Use Vulkem or Sikoflex.
Old 06-09-2011, 12:31 PM   #4
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Andy's right, use Vulkem or Sikoflex. The best is simply to remove the little windows completely by cutting through that old stuff. Use Vulkem/Siko to rebed the windows.
Be sure also to seal around those upper hinges on the larger windows. Andy has instructions for it. Those hinges on the 66-67-68 rigs are the ONLY areas on the Airstream where you use silicone.
Lynn
WBCCI 21043
Old 06-09-2011, 04:04 PM   #5
1966 30' Sovereign
Thanks. Already did the hinges above. The top ledge is dry and the bottom gets wet still.
Old 06-09-2011, 04:13 PM   #6
1966 30' Sovereign
Btw is there replacements gaskets for the back side/ inside of the windows?
Old 06-09-2011, 05:02 PM   #7
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
You mean the little windows that you have the picture of? If so, no, those are the dreaded NLA. That's why you'd remove all the old stuff and create a bedding for the windows with Vulkem. (At least I see NLA a lot less often for the Airstream than for my MGB.)
Actually, I kind of can't wait until next week. We're going to have some folks here coming back from the restoration rally in Albuquerque, and they have the spitting image of our rig!
Lynn
WBCCI 21043
Old 06-13-2011, 09:05 AM   #8
1966 30' Sovereign
On the subject of removing these windows, ho do you do it. Do you have to remove this piece with the three rivets on each side? Or is there a different way? Help always appreciated.
Old 06-13-2011, 11:08 AM   #9
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Nope, no need to remove that piece!
I used a sharp cutter and sliced through the visible lip of the old rubber/plastic seal from the inside. With that removed, you're able to see how things work and begin taking out the window itself.
Lynn
WBCCI 21043
Old 06-13-2011, 06:04 PM   #10
1966 30' Sovereign
Thanks Lynn I will give that a try.
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 14 09-13-2018 08:05 PM
'58 Hehr Window - Is this the correct window operator replacement? mello mike Windows & Screens 22 10-08-2012 08:49 AM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
2007 Classic front center window glass/frame interference dznf0g 2006 - 2010 Classic (all lengths) 0 03-23-2011 09:44 AM
