Old 01-13-2003, 08:00 PM   #1
Question Louver window replacement
Can anyone tell me where I might find replacement glass for the louver type windows found on the early '60s Flying Clouds and Safaris? Thanks.
63flyingcloud is offline   Reply With Quote
Old 01-13-2003, 08:45 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings 63flyingcloud!
There isn't anything unusual about the glass utilized in the jalousie windows in your 1963 FlyingCloud. So long as you have the spring retainers, any copetent glass shop should be able to cut a replacement pane when provided with the proper dimensions. You might want to consider a more modern tempered glass as the original was standard window glass if it is like my '64 Overlander.
Kevin
Kevin D. Allen
AIR #827
Old 01-14-2003, 01:29 PM   #3
Thanks, Kevin. Jalousie windows! You learn a new word everyday with this new hobby!
My glass looks to be an auto safety glass (some kind of plastic sandwiched between glass). The problem that developed is that where one window overlaps and touches the next, the glass is discolored (as if the plastic in the middle of the "sandwich" has melted). Perhaps this area was subject to greater heat.
Anyway, thanks for the info--I'll try a good glass shop.
Old 01-14-2003, 01:44 PM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Welcome aboard 63flyingcloud!
You will find a wealth of knowledge here on the forums...and before long you'll have lots of experiences to share!
Good luck!
Shari
Old 01-14-2003, 04:19 PM   #5
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
It does sound like you may have a "safety glass" product in your jalousie windows. Mine and most of the others that I have seen, have standard, non-tempered window glass in the side jalousied windows. The tempered safety glass is a plus from a safety standpoint, but it sounds like it is behaving like automotive safety glass of similar age - - bubbling and separating - - I know that the vent-panes and one side window on my '65 Dodge are starting to bubble and separate. I still believe that a competent glass shop should be able to help with replacements - - especially if you can provide an original window pane to use as a pattern (and to match the glass composition <thickness> as closely as possible).
Kevin
Kevin D. Allen
AIR #827
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 11:49 AM
Window replacement for 1970 Safari nds Windows & Screens 2 03-08-2004 01:07 PM
Report of window replacement in 1977 Minuet 6.0 kenny All Argosy Trailers 2 08-27-2003 08:11 AM
Window Frame Replacement Charles D. Bennett Windows & Screens 20 08-16-2002 07:03 PM
