Old 08-23-2010, 02:47 PM   #1
Twin Lakes , Wisconsin
Lost a window on our trip this weekend....yikes....
So someone forgot to latch one of the windows on our 69' Land Yacht....the rest of the story in on the side of the highway in WI. But I found some for sale from a 72' Land Yacht. Will these work???
redreefet is offline   Reply With Quote
Old 08-23-2010, 03:00 PM   #2
1970 on up windows will not work on a 69, because the hinge is different.
If you attempt to install an opening window in a 69, that has the wrong hinge, then you will shear off the rivets that hold the hinge in place.
Unfortunately, if you want to install a opening window in a 69 trailer, you can only obtain a later model window, BUT" you must change the hinge. to match the 69 hinge arrangement.
Or, find a used window from a 69 trailer.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-23-2010, 04:31 PM   #3
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
...ask Andy up above if inland has a replacement for your needed fix. We replaced ours back to the original after loosing it to the fate of a weedeater..(I hate those things) Good luck fixing the problem. You can see where we 'contact papered' it when it got busted...and then the second picture is the new one we are so darned proud of. It was close to a four hundred dollar fix, but in the long run it was 'key' to keep the originality of the Airstream in tact and solid.
ID:	109221   Click image for larger version
https://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 08-23-2010, 08:35 PM   #4
Kevin245's Avatar
There are some 69 windows listed in the classifieds you may want to investigate.
1969 Curved Glass Windows - Airstream Trailer Classifieds - Used Airstreams For Sale
William C. Swinney
Lost Trailer Brakes This Weekend DEITZ645 Brakes & Brake Controllers 26 05-16-2009 04:43 PM
Nice weekend camping trip then......DISASTER!! chuman70 Repairing/Replacing Floor &/or Frame 4 04-27-2008 10:42 PM
double glazed window film inside? Yikes! ray henton 1974 - 1979 Safari 2 07-05-2006 05:39 PM
Lost a Window Bob&Rita Windows & Screens 2 05-31-2005 06:33 PM
Trip report - Lost Maples SNA, TX Pahaska On The Road... 1 08-03-2002 09:28 AM
