Is Liquid Wrench Silicone spray O.K. to use as the silicone spray for my
new window gaskets after the gaskets have been replaced?
I have read to open the windows after a few hours and spray the new gaskets, shut windows and then in a few days to open the windows and wipe down the excess silicone.
If this is not the correct silicone spray, could someone please tell me a correct brand that would work.
Jane
Airstream recommends 303 protectorant for the window rubber on all new units. I use it and it prevents the windows from sticking to the rubber. The silicone spray you mentioned will work fine also,. It's a good product and as mentioned earlier has other uses as well.
I sprayed our window gaskets with Teflon mold release. No sticking after that, although, I suspect this has no affect on preserving the rubber (not sure any aftermarket product actually helps much).
