Old 05-29-2014, 09:37 AM   #1
1969 18' Caravel
Carlsbad , California
Lexan versus Glass
I suffered a broken back window on my 1969 Caravel and am considering replacing the glass with plastic? Any opinions on the pros/cons?
pathurley is offline   Reply With Quote
Old 05-29-2014, 10:27 AM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I replace the rear window on my 68 TW twice. The first time it was to replace the plexiglass the PO had installed. It leaked. Second time was because my wife forgot to loosen the center clip on the bottom before she cranked it open and crack. I used regular glass I had cut at the local glass shop. Why not tempered? I figured the rear would not have problems with impacts and it was much cheaper.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 05-29-2014, 12:05 PM   #3
Taking the 45 year old sash apart, you will find to be extremely challenging.
Old 05-29-2014, 12:23 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
If you use Lexan get the UV resistant type. Lexan is better than Plexiglass, but I would prefer glass. The rear window could probably be done at a local glass shop.
Old 05-29-2014, 02:40 PM   #5
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
I used lexan on a replacement of tempered glass on boat, smoke tint matched other windows and worked great. No deteriation or change due to sun in five years.
Old 05-29-2014, 04:20 PM   #6
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
Remember, plastic is much softer than glass - used it once (Lexan) on boat - friend wiped it off without water - would use glass.
Silver Hawk is offline   Reply With Quote
Old 05-29-2014, 05:24 PM   #7
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
Tough water spots can't be steelwooled off of plastic. It scratches.
2007 28' Int CCD.
2011 F 250 Big Honking Diesel
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Two big screens
15dB Backfire WiFi antenna and WaveMagnum
Centramatics.
Hawkshead Tire Monitors.
henw is offline   Reply With Quote
Old 05-30-2014, 04:20 PM   #8
Lexan scratches just as easy as regular plastics, UNLESS you specify AR-2 , which means "Abrasion Resistant".
0000 Steel wool, will not scratch it, as I have demonstrated to many customers.
drilling Lexan? pinkflamingoes Windows & Screens 28 01-05-2013 06:43 AM
replacing windows - glass, lexan, tempered glass? BrianY Windows & Screens 4 07-01-2010 12:08 PM
Thickness of Window Glass/Lexan Pschoerrn Windows & Screens 15 10-28-2009 05:12 PM
SF Bay Area - Need Help w/ Lexan (polycarbonate) source Mookie Windows & Screens 3 03-19-2007 09:56 AM
