Old 07-08-2007, 04:21 PM   #1
campngirl's Avatar
1964 24' Tradewind
dousman , Wisconsin
Jalousie windows stuck
Hi,
My jalousie windows are stuck .
Has anyone unstuck jalousies? Have already replaced the crank mechnisms.
Rivets that connect pane holders to the uprights are rusty. Has anyone found a lubricant that frees movement and keeps movement free? Has anyone drilled out old rivets and replaced them?
Thank,
Karol
campngirl is offline   Reply With Quote
Old 07-08-2007, 04:27 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I found Howe's Oil was best at freeing rusted parts. I have also replaced several rivets on windows, it's not too tough. I used a thin shim to keep the rivet loose enough to pivot.
Old 07-08-2007, 04:33 PM   #3
campngirl's Avatar
1964 24' Tradewind
dousman , Wisconsin
Thanks Terry. That was my next question.... about the spacing to enable a pivot.
Karol
Old 02-23-2011, 08:58 PM   #4
1960 24' Tradewind
replacing jalousie rivets?
I see that Terry has replaced rivets on the jalousie clips.. I have the same problem, so what kind of rivets were used? I'm thinking of using 1/8" aircraft style, but I'd have to buy an offset tool for the rivet gun. Any other alternatives?
the wall of enclosing the clips gets in the way of using a normal pop rivet gun or normal impact tool.
I thought of putting a shim between part at rivet time to keep the joint free to rotate, good to hear that Terry used the same technique.
PetervB is offline   Reply With Quote
Old 02-24-2011, 07:18 AM   #5
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
I used boeshield on my mechanism. Fortunately, mine were in good condition. Boeshield is a waxy based lubricant used to keep tablesaws from rusting. I also use it on router bits. Spray, and lightly wipe it off. Doesn't have a smell like wd40, but it can stain something like zolatone.
robwok is offline   Reply With Quote
Wondering what kind of glass to use for replacing all windows in 1958 Traveller williamhenshall Windows & Screens 3 08-19-2007 07:15 PM
Water leak panoramic windows Andy Fay Windows & Screens 16 01-05-2007 08:33 AM
Windows Inland RV Center, In Windows & Screens 1 04-20-2004 06:14 AM
Tinting Windows.... kzener40 Airstream Motorhome Forums 8 09-09-2002 09:12 PM
Caravel windows susan martin 1966-68 Caravel 1 08-21-2002 08:43 AM
