Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 07-06-2008, 02:16 AM   #1
wiegand01
wiegand01's Avatar
Profile:  1964 22' Safari
Granite City , Illinois
Jalousie Window Questions
I've looked and can't find the answer. I have the jalousie windows, and they haven't been taken care of. There aren't any seals and some of the clips are horrible. I ordered replacement clips and some of the seals. My questions are:
Where are all the seals supposed to be one the Jalousie Windows?
How do you remove the glass panes form the Jalousies?
What seals the bottom of the very bottom jalousie?
Does anyone have a picture of the exterior trim of the top Jalousie window in a trailer with the stacked Jalousie's?
Thanks in advance
Nick
wiegand01 is offline   Reply With Quote
Old 09-03-2008, 09:35 AM   #2
3Ms75Argosy
3Ms75Argosy's Avatar
Profile:
Just bumping this, as I too now have to fix some Jalousie's...
Marc
Old 09-03-2008, 10:24 AM   #3
dwightdi
Profile:  1977 31' Sovereign
McHenry , Illinois
The lowest jalousy bumps up against a furry window seal strip like in a car. There are no seals between the other panes and so they always leak air, unless you put a fixed acrylic panel in to replace the screens on the inside. I bent the aluminum clips to get mine out. You might be able to just push on them enough to get past the stop without bending the aluminum. I had to buy two new panes as someone tried to break in by reaching thorough the panes they broke. Luckly, the dead bolt was one that you can only use keys on the inside as well as the outside.
Old 09-03-2008, 10:53 AM   #4
Overlander & Sea
Overlander & Sea's Avatar
Profile:  1961 26' Overlander
Gulfport , Mississippi
I purchased seals and weatherstrips for my Jalousie windows from Vintage Trailer Supply (www.vintagetrailersupply). They had both the seals that fit onto the bottom of the glass for sealing between the glasses (order by the foot) and the weatherstrip that fits in the channel of the AS below the bottom glass that seals the lower part of both bottom glasses. I cannot find the clips, VTS shows them, but are out & they say they're discontinued.
Rick, JJ, Tommy, and Will
1961 26' Overlander International Land Yacht
WBCCI #9275
"So, why do we drive on a parkway and park on a driveway?"
Overlander & Sea is offline   Reply With Quote
Old 09-03-2008, 11:41 AM   #5
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 104
For the glass retainer clips, you might try the local yellow pages. Look for a shop specializing in screened porches, sun rooms, etc. that has been in business for quite a time. They are one of the more likely sources. Another possibility if you live in or near a University town where there are trailer parks with older mobile homes are, look for a mobile home repair shop and check with them -- that is how I found some extras about five years ago (unfortunately, that shop closed when highway reconstruction went through the business' property). You might also try checking architectural salvage yards -- you might have to buy a complete jalousie window unit, but it might yield a treasure-trove of extra replacement parts. An active remodeling contractor might also be able to help with locating a "used" parts window.
Kevin
Kevin D. Allen
AIR #827
Jalousie windows stuck campngirl Windows & Screens 2 07-08-2007 04:33 PM
60's Window questions Safari Tim Windows & Screens 27 12-13-2006 06:37 AM
jalousie window Coolnotcheap Windows & Screens 1 09-29-2005 03:36 PM
Jalousie Window Clips greg176 Windows & Screens 1 03-23-2004 10:55 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
