09-12-2010, 10:16 PM
1964 22' Safari
Eagle River
, Alaska
Jalousie seals
What kind of seal, pile weatherstrip,etc. goes at the top and bottom of Hehr Jalousie windows on a ’64 Safari?
VTS has the side pile weather strips, and retainer discs and also lists clear windowpane seal (out of stock and not original on travel trailers).
Is there supposed to be a weather strip or seal across the top?
What goes on window frame where bottom pane contacts frame (more pile weatherstrip glued in place)?
09-12-2010, 10:22 PM
1963 24' Tradewind
Anderson / Sun City
, Indiana / Arizona
My trailer is at P&S getting a new gray tank, but I believe that the Bulb Seal available at Vintage is what you need.
09-12-2010, 10:31 PM
1951 21' Flying Cloud
1960 24' Tradewind
Folsom
Generally I have been very "pleased"/happy w/everything I have bought from VTS . . . however those "clear windowpane seals" were useless. They would not stay in place - great idea, they just don't work.
I did buy all the other Jalousie window gaskets, pile strips, retainer discs . . . and they work great.
I haven't found a replacement for the bottom of the frame. Mine is still existing in place but rather hard, it's basically a bulb shape.
MarkR
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
09-12-2010, 11:21 PM
1964 22' Safari
Eagle River
, Alaska
Seal source
Looks like the bulb seal will fit top and bottom. Tried to order but VTS shows out of stock for all the seals I need. Inland doesn't show them listed (I could call).
Does anyone have another source for the side pile weatherstrip, bulb seal and disc material?
Where are mobile home/Florida home jalousie parts?
09-13-2010, 12:02 AM
1964 22' Safari
Eagle River
, Alaska
Hey MarkR,
When the clear seals were on did they seal?
Would a film of clear silicon/heat gun/super glue help hold them on?
There's a lot of air leaking between the panes and rattling when the wind blows. The wind always blows.
How did you cut the discs?
09-13-2010, 12:04 AM
1964 22' Safari
Eagle River
, Alaska
Hey again MarkR,
Do you know a glass shop near Folsom that can cut jalousie panes in a day or two? Seems I left one somewhere near Truckee on I-80.
Doing time in Folsom for a bit.
09-13-2010, 08:20 AM
1960 24' Tradewind
Folsom
"Doing Time in Folsom" . . . there's a lot of folks "doing time in Folsom" . . . mostly against their will.
Jalousie Glass: Kidwell Glass in Orangevale on Greenback Lane made mine, they are (and should be) laminated glass. They might be able to make them while you wait (?) 916.989.5507.
The Disc Material: I just used a razor blade to cut my discs - I might have some left over (and I might be able to find it (?)). You're welcome to it if you need it.
Clear Seals: I didn't use anything to attach them - for some reason, that I can't now remember, I didn't try that.
09-13-2010, 07:57 PM
1963 22' Safari
2020 27' Globetrotter
State of
I've found on our 63 that Jelousie windows and seal are hard to put in the same sentence.. they all leak. My factory windows had a "J" shaped moulding that had a channel across the top over the top pane that it slid into. The top window has a round grove for piece to go in, the bottom has the "T" shaped that the part slide in, and neither VTS part no matter how much soap or anything will go in either, so right now we're going without. The bottom rested into the jelousie bulb seal VTS sells (vintage trailer supply). I hope that helps. They also sell the fuzzy stuff that slides up the sides to keep the water out of that area.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
11-10-2010, 05:23 PM
1963 19' Globetrotter
1963 22' Flying Cloud
1963 24' Tradewind
My Jalousie windows on my Tradewind have had all the seals replaced, put vulcom around where the frames attach to the trailer, and there still leaking I just don't get it maybe I need that j shaped molding on top of both frames? The seals are kind of tough to get in but do fit. Got every seal from VTS.
Psalm 67:7
11-10-2010, 06:51 PM
1963 22' Safari
State of
I think all Jalousie windows will leak, no matter what.
Scott & Megan
01-29-2011, 08:33 AM
1958 26' Overlander
Mesa
I assume the retainer disks are wedged into place and don't require some kind of adhesive to stay in place, correct?
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
01-29-2011, 10:34 AM
1963 24' Tradewind
Anderson / Sun City
, Indiana / Arizona
I didn't use any adhesive on mine, and I have not lost one disk in over 15,000 miles of towing.
Mike Brumback
WBCCI #1200
01-29-2011, 11:44 AM
1958 26' Overlander
Mesa
Yep, installed the retained disks today. Simply wedged them into place. The disks and window panes aren't going anywhere.
1958 Overlander
4CU 1st VP
01-29-2011, 04:13 PM
1976 25' Caravanner
Campton
, New Hampshire
If the flap seal at the top of the window doesn't extend to the outter edge of the frame it will leak at the corners. Also caulk the lower frame corners ,where it goes into the wall , not on the face where the rivits are .
03-13-2017, 07:12 PM
1970 29' Ambassador
1959 22' Flying Cloud
1957 26' Overlander
Ashland
, Oregon
Can I ask what thickness the glass for jalousie windows are? I am thinking they are 1/4" as the metal clip on the ends is so thick. Thanks!
03-13-2017, 10:08 PM
1960 24' Tradewind
Folsom
mine are 2 layers of 1/8" laminated together
03-14-2017, 09:54 AM
1964 24' Tradewind
2006 39' Land Yacht 396 XL
Lawrence
, Kansas
I rebuilt mine last summer. It is in storage so I can not go look at it but has I remember, here are some of the things I learned. VTS had a seal that worked at the top. I believe it has a bulb with a T that slid into the slot. This stretches when putting it in so leave some extra at the ends and wait a day to trim it up. The little disks that hold window work great. You may need to tighten the clip so they hold better. The fuzzy trim at the sides also works well but I had a lot of trouble getting the old trim out. WD 40 did not work but a liquid wrench soaking did. I believe they had a trim with a little flap that I used on the bottom (again leave extra and then trim). The clear trim they sell for the bottom of the panes does not work. If you need to replace a pane just go to a good glass shop. You will never get it to seal completely but you can improve it. I took out all the panes and cleaned and oiled the hinges. I spend a lot of time trying to clean out the trim slots. I put any thing I could think of to loosen grime and repeatedly blew out with air.
