Old 05-26-2006, 09:29 PM   #1
Angel73's Avatar
1975 31' Sovereign
Woodlawn , Tennessee
Images: 65
Send a message via Yahoo to Angel73
Unhappy It won't stick.....blank _____!
I have tint and pulled the vista window out twice now and cleaned it and put it back...It won't not seal for nothing what am i doing wrong,Am using trempro nice bead around the window then putting it in place letting it set for three days before touching and its still leaking both times.....Should i fell the frame with a pretty thick bead too?
The Clark Family
Angel73 is offline   Reply With Quote
Old 05-27-2006, 05:38 AM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I take it you are trying to reseal the vista view glass to the frame? On mine I used A LOT of Vulkem between the glass and the frame, then wedged the glass in place with some thick tubing to hold it in place. Then went around on the outside with a bead of sealant too. So far no leaks in the VV except from the new window from the factory and that one has finally been sealed.
Aaron
WBCCI #XXXX AIR #2495
Old 05-27-2006, 05:43 AM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
It may be a hue mistake, but I finally decided to take mine out. I've never liked the idea of the sun beating down on that poorly insulated panel, anyway.
Old 05-27-2006, 12:00 PM   #4
Angel73's Avatar
1975 31' Sovereign
Images: 65
yea
Aaron
I didnt have much of a choice when i went to remove the last vista window(the plastic one) to scrap off the old tint to replace with new both windows came out...Guess that exsplain some more of the leaks we where having in the rear....Now if i can just get it to stick going in for the third time...wish me lucky
The Clark Family
Old 05-27-2006, 09:10 PM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Angel,
Sounds like the retainer clip is missing or not doing its job. I don't have the same style window as you do. I have the newer version. If you look in Photos section someone did a complete rework of the style of vista views that you have.
Aaron
Old 05-27-2006, 09:29 PM   #6
Angel73's Avatar
1975 31' Sovereign
Images: 65
Humm
Angel,
Aaron
ill look again for pic ...but i didnt see then before...there are two clips on the bottom only..... should there be more on each window?If so do you know who would have them?
The Clark Family
Old 05-28-2006, 05:06 AM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Angel,
I was under the impression that it had a big retainer ring that went all the way around ? I will see if I can find the pictures, they might have been in a thread too.
Aaron
Old 05-28-2006, 09:34 AM   #8
Angel73's Avatar
1975 31' Sovereign
Images: 65
Angel,
Aaron
yeah there is a silver retainer ring that goes against the second plex window is this what your talking about...But all it does is hold the second window in place and keeps the first window from falling out...lol like it did on me when i removed the ring....lol
The Clark Family
wanted key blank for 69 Overlander bgow 1969 Overlander 4 10-04-2015 11:15 PM
Dip Stick Bill Resseau Mechanics Corner - Engines, Transmission & More... 26 11-09-2010 04:08 PM
AirstreamForums.com Member Sticker? Andy R Our Community 171 06-08-2007 10:12 AM
Camper airstreamcaravel Off Topic Forum 48 09-03-2002 07:09 AM
