Old 05-01-2011, 06:36 AM   #1
2011 28' Flying Cloud
chanhassen , Minnesota
Interior Aluminum Flange for Fixed window
While working on removing the window screens and two flanges that go around the two fixed windows on m '76 G/T, I had laid a piece on the driveway and my wife accidentally rolled over the piece in this picture.
Tried banging it back to original form but no go.
Is a piece this still available? I'm thinking it is not. In that case, where could I go to have someone make one for me? I know it's aluminum and I think the process is called brake metal? Does that sound right?
The window flange, made of aluminum is @ 20.5" wide x 10" high.
Ken in MN
kentuvman is offline   Reply With Quote
Old 05-07-2011, 06:43 PM   #2
Well okay than!
Since part may not be available, does anyone have a suggestion on where to go and find a shop that does aluminum fabrication - I think it would be a brake metal machine?
Suggestions appreciated!
Old 05-07-2011, 06:47 PM   #3
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Your best bet is probably any sheet metal shop.
Cutting it to the correct size and getting the 90 degree angles should be no problem.
Getting it bent to the oval shape is going to be the booger, but the sheet metal guys can probably do it. Don't let them BS you.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 05-07-2011, 06:50 PM   #4
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
I can't help much but if I had to make that I'd use a brake for the crease then a shrinker-stretcher. A brake is used to bend metal in straight lines. You might try a local aircraft school. Sorry I can't help more.
truckasaurus is offline   Reply With Quote
Old 05-07-2011, 07:09 PM   #5
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
You could make it out of some aluminum angle & use a "stretcher" to create the the radii. Stretchers are available at Harbor Freight & other metal fabricator suppliers online. They aren't very expensive but this may be the only job you might have for it.
Another option would be to contact Ryan at www.rvrevive.com . He buys wrecked Airstream's & parts them out. He's a fair guy & knows his stuff.
Good luck with it,
Colin
Colin H is offline   Reply With Quote
Old 05-08-2011, 06:17 AM   #6
Thanks so much! I knew there had to be a solution!
Old 05-08-2011, 06:46 AM   #7
jackson center , Ohio
You can contact Camper Repair in Montevallo,Alabama and speak with Sony Hare. He may have the size you need. Also Airstream still uses the window trim rings on new models but they only have bare aluminum.
Schu is offline   Reply With Quote
Old 05-14-2011, 03:52 AM   #8
n8andm's Avatar
Minneapolis , Minnesota
Since you live in MN I would go to Discount Steel & Aluminum, they do fabrications. Also my metal worker friends suggest Garelick's.
_______________
/.:N8andM.in.MN:.\
|:Silver Streak Jet:|
n8andm is offline   Reply With Quote
Old 07-16-2011, 07:28 PM   #9
Resolution
Well, I couldn't find anyone who had another piece for sale and the quotes I got were north of $500.
So, I showed it to a friend a retired mechanical engineer, and he helped me bang out the dents with a small hammer. I used bondo to make it close to brand new.
Sometimes you just need to be creative!
Thanks for your suggestions - appreciate it!
Old 08-08-2011, 09:06 PM   #10
1994 34' Excella
Warren , Manitoba
If you are looking for older Airstream parts, try Hart Trailer Sales in Long Prairie MN. they were dealers for Airstream years ago and still have lots of old parts and aluminum extrusions. Talk to Wayne Rahn, Parts and Shop Manager. Great Guy to talk with and knows his stuff. Ph #320-732-6106
CBWELL is offline   Reply With Quote
'58 Hehr Window - Is this the correct window operator replacement? mello mike Windows & Screens 22 10-08-2012 08:49 AM
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 13 01-05-2012 06:41 PM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
Got my window out. Now what? Breadbug Windows & Screens 3 01-23-2011 07:27 PM
