Old 08-13-2016, 02:07 PM   #1
1978 31' Sovereign
Edmonton , Alberta
Installing Argosy Wrap Around Windows on a 1978 Airstream Sovereign 31'?
I am thinking about installing the Argosy wrap around windows on my 1978 airstream 31 foot sovereign with rear bedroom. Has anyone ever done this before? Will they fit without much modification? As far as I can tell I just have to cut the aluminum out to accommodate the larger wraparound window versus doing windows. Other than the interior molding, is there anything else I need to consider?
Thanks advance for your feedback. Loving the forum.
Michael Wild
planBe is offline   Reply With Quote
Old 08-13-2016, 02:15 PM   #2
1979 23' Safari
Wayland , New York
Where is the univolt and 12vdc fuse panel in your trailer?
There could be some wires running from the center overhead down in those areas. Or up from the tow umbilical plug up to the overhead to run aft.
Would require a little wire splicing and rerouting.
Old 08-14-2016, 10:30 PM   #3
1978 31' Sovereign
Edmonton , Alberta
I am not too worries about the wiring, mostly concerned about the frame that runs around the windows.
Old 08-15-2016, 08:36 PM   #4
1979 23' Safari
Wayland , New York
Where those wing windows go the first frame will be where the curve meets the end cap. There is a little but below the front window. But beyond that it's open from the bottom of the window back to the straight transition.
Old 09-05-2016, 12:41 PM   #5
Cragnomad's Avatar
1976 Argosy 24
SLC , Utah
Where did you get the windows from? I'm looking for one myself.
Cragnomad is offline   Reply With Quote
sovereign
Airstream/Argosy wrap around windows topd1 Airstream Classifieds 1 02-10-2014 07:13 PM
Wrap around rear windows jessl Member Introductions 1 11-25-2006 01:31 PM
Wrap around windows - front and rear? SilverToy Off Topic Forum 5 11-02-2005 12:55 AM
Wrap-around windows on NEW Safari? Soarhead Our Community 3 07-30-2004 10:07 AM
front wrap-around windows Daryl Windows & Screens 6 11-28-2003 09:29 AM
